302 engine issues.
Old Nov 4, 2018 | 11:18 AM
  #181
Tedster9's Avatar
Tedster9
Originally Posted by baddad457
Maybe it's just me but you just contradicted yourself here. Fuel pumps don't have pressure ? Yet someone had 18.5 psi ? all that aside it takes very little flow to supply enough fuel to keep the bowls fed. Too much flow will cause too much pressure on a carbed engine. I'm using a 35 gal/hr electric to feed 3- two bbl Holleys on my 331. Even at WOT for a mile or two, they're fed enough fuel. Only time it fails is when the inline filter gets clogged, and that just serves to remind me it's time to change the filter.
Because they achieve their greatest flow at the lowest pressure, the pressure output is not fixed, consequently a pump doesn't "put out" a specific pressure.
Old Nov 4, 2018 | 12:13 PM
  #182
xlt4wd90's Avatar
xlt4wd90
Is that wet area outside of the sealing shoulder of the plug? That means the wetness if from outside the cylinder, nit inside.
Old Nov 4, 2018 | 12:54 PM
  #183
baddad457's Avatar
baddad457
OK, then why are there low pressure and high pressure pumps ?
Old Nov 4, 2018 | 12:59 PM
  #184
baddad457's Avatar
baddad457
Originally Posted by BeauF0RD
At this point the hesitation or stumble is at cruise mostly in third gear after i get off the throttle when I get back on the peddle it does it. I have a three speed manual shift on the floor.
I would look at the accelerator pump. It should squirt fuel the instant the throttle lever moves. It may not be doing this. You can check this with the engine off by looking at the squirters and moving the throttle lever on the carb. I would also check the vacuum diaphragm on the distributor to make sure it's working. Remove the cap and unplug the hose from the carb and watch to see if the breaker plate in the distributor moves when you suck on the hose.
Old Nov 4, 2018 | 03:16 PM
  #185
BeauF0RD's Avatar
BeauF0RD
baddad457, Thanks again for your interest, my accelerator pump squirts instantly when I move the throttle lever. I just went out and pulled off the distributor cap and sucked on the hose and the breaker plate did indeed move.
Old Nov 4, 2018 | 05:10 PM
  #186
Tedster9's Avatar
Tedster9
Some engines need more fuel than others.
Old Nov 4, 2018 | 08:42 PM
  #187
baddad457's Avatar
baddad457
We're talking about a mild 302 build here. Which uses very little fuel. You can empty the fuel bowl by half and the flow going into the engine through the circuits will not change. His spark plugs don't indicate a rich condition. His fuel pump may not be supplying enough to keep the bowls filled here. Either that or there's something going on with the wiring to the distributor causing a short could be the source of the stumble.
Old Nov 6, 2018 | 05:30 PM
  #188
BeauF0RD's Avatar
BeauF0RD
Thanks again baddad457, I plan on getting my fuel pressure checked as soon as I can get the proper T fitting to hook my vacuum/fuel pressure gauge into my fuel line. I also want to increase my jet size from 62 to 64 to see if that will help with my hesitation issue, my carb is set up with size 62 jets,35 squirter nozzle,and a 9.5 power valve. I also will have my neighbor help me look over the electrical with his multi meter. Any more guidance on what all electrical checks we should do would be appreciated.
Old Nov 6, 2018 | 06:50 PM
  #189
Tedster9's Avatar
Tedster9
No, we're not, we were talking about fuel pumps. If you want to change the subject, that's OK too.
Old Nov 6, 2018 | 07:40 PM
  #190
baddad457's Avatar
baddad457
I'm not changing the subject. You went off in one direction, I'm trying to help him on another possibility.
Old Nov 6, 2018 | 07:44 PM
  #191
baddad457's Avatar
baddad457
Check both the hot and negative going into the distributor. If you're running an aftermarket tach, check the green wire connected to the distributor negative, contrary to what you might think, if this wire touches ground, like in passing through the firewall, it will kill the power to the distributor. Learned that one the hard way many, many moons ago.
Old Nov 7, 2018 | 05:12 PM
  #192
BeauF0RD's Avatar
BeauF0RD
Thanks baddad457, we will check the wiring you mentioned and I do have a aftermarket tach also. I stopped by the local speed shop and the counter guy suggested that I adjust the red accelerator pump lever spring in one rotation at a time in between drives to see what kind of change it would do to the hesitation and also try turning out one rotation from the spot it is currently at now to see how the engine reacts hopefully I will have good success with this method, can't hurt to try.
Old Nov 10, 2018 | 04:47 PM
  #193
BeauF0RD's Avatar
BeauF0RD
I tried to check my fuel pressure with my vacuum/fuel gauge today, it was going well until I noticed gas leaking where the vacuum hose connects to the bottom of the vacuum/fuel gauge so I quickly shut down the truck. Before I shut the truck down I noticed my fuel pressure was at 9 psi on high idle. I need to get a band clamp that fits better and maybe I should get fuel hose the same size as my vacuum hose to be on the safe side. Anybody with experience on checking fuel pressure want to give me some advice on how to properly and thoroughly check the fuel pressure. Thanks
Old Nov 10, 2018 | 07:01 PM
  #194
baddad457's Avatar
baddad457
If you had 9 psi with a fuel leak your pressure is definately too high
Old Nov 10, 2018 | 09:15 PM
  #195
Tedster9's Avatar
Tedster9
Maybe it's just me
It's just you LOL
