302 engine issues.
Old Jun 22, 2019 | 09:42 AM
  #301
BeauF0RD's Avatar
BeauF0RD
Originally Posted by xlt4wd90
You check the lash of each cylinder using the old procedure of turning the crank until the valves are closed. Then turn the bolts down until they take up all the gaps between the rockers, pushrods, and lifters. Then you should be able to turn the bolts about 3/4 turn to torque them down. That should push the rods about .030" into the lifter plungers. If the rods push in much more than that, you can install a shim under the pedestal. I did that recently with a newly rebuilt set of heads, and they've been running very quietly after warm up, with only a slight tick right after start up. Of course, mine are rollers, so they did not need that initial 2000 rpm for 20 minute break-in.
To do this I need to remove my spark plugs to rotate engine?
Old Jun 22, 2019 | 10:47 AM
  #302
baddad457's Avatar
baddad457
It would help. I use a breaker bar and 15/16" socket on the crank when I do the valve lash on my 331. One quarter turn for each cylinder in the firing order. Start with #1 at TDC and one quarter turn for each till you get to #8
Old Jun 26, 2019 | 03:20 PM
  #303
BeauF0RD's Avatar
BeauF0RD
Moving at a snails pace, I have decided to remove all the rockers and examine them as well as the push rods before going through the torquing cycle. I found the #2 cylinder exhaust lash cap is wearing unevenly and the push rod rolls with a very slight wobble. So now I need to take the #2 exhaust pedestal rocker assembly with push rod to a shop that builds engines and ask their opinion on how to best handle this. I hope it's as simple as replacing worn parts. The #1 cylinder exhaust valve rocker was tapping and was the reason for opening up this whole can of worms.
Old Jun 27, 2019 | 11:20 AM
  #304
BeauF0RD's Avatar
BeauF0RD
Also cylinder #5 intake rocker was dry even though when I sprayed the push rod with brake cleaner there was no blockage?
Old Jun 27, 2019 | 05:34 PM
  #305
baddad457's Avatar
baddad457
I would pull that lifter and see what's wrong there. Could be no oiling hole in the side. Someone in the FE big block section found a new roller lifter missing that feature.
Old Jun 27, 2019 | 11:45 PM
  #306
BeauF0RD's Avatar
BeauF0RD
I've had the valve covers off this engine before and had a dry rocker but it was because of a blocked push rod. What ever is going on with this cylinder is something that began since the last time I had the valve covers off.
Old Jun 29, 2019 | 03:40 PM
  #307
BeauF0RD's Avatar
BeauF0RD
Okay so I got the valve lash set on all cylinders. I have pedestal rockers and there is so much confusion as to how to torque down the rockers. My neighbor says to just tighten them down because they simply bottom out, many others seem to agree. I contacted the Ford racing tech line and the tech said to remove the rockers and watch as the push rods go up and down starting with cylinder one at TDC, when both push rods are all the way down put the rockers on and tighten the bolt by hand until all the lash (up and down play) is out between the rocker and push rod. Than torque both rockers down to 22 Ft. lbs.. He told me to just go from cylinder one to two to three etc.etc.etc.until done. All of the bolts torqued down between a 1/4 turn and just shy of one full rotation. I could shim various rockers to make them all closer to 1/4 turn, should I bother?
Old Jun 29, 2019 | 08:51 PM
  #308
baddad457's Avatar
baddad457
Okay so I got the valve lash set on all cylinders. I have pedestal rockers and there is so much confusion as to how to torque down the rockers. My neighbor says to just tighten them down because they simply bottom out, many others seem to agree. I contacted the Ford racing tech line and the tech said to remove the rockers and watch as the push rods go up and down starting with cylinder one, when both push rods are all the way down put the rockers on and tighten the bolt by hand until all the lash (up and down play) is out between the rocker and push rod. Than torque both rockers down to 22 Ft. lbs.. He told me to just go from cylinder one to two to three etc.etc.etc.until done. All of the bolts torqued down between a 1/4 turn and just shy of one full rotation. I could shim various rockers to make them all closer to 1/4 turn, should I bother?
No need to watch the pushrods. Just start with #1 cylinder at TDC on the firing point. Both valves are closed at that point. Then when done, move onto the next cylinder in the firing order after rotating the crank one quarter turn. That's if you want to check the preload. On stock motors I just torque em all down at the same time and call if good. Never had an issue because of this. I did the 351 like this in my 96 E150 van 6 years and 50K miles ago. Valvetrain's quiet as a mouse with Cobra rockers. Only thing I did do was install new pushrods then. And this done because roller cams don't rotate the pushrods when in service. This causes the rocker ends to wear to a somewhat knife edge.
Old Jun 30, 2019 | 10:38 PM
  #309
BeauF0RD's Avatar
BeauF0RD
Question, I'm still working through trying to understand this whole adjusting valve lash on pedestal rockers. I was told to adjust them on TDC compression stroke and be sure not to adjust them on the over-lap stroke( I assume that's 180 degrees wrong). With the rockers removed from cylinder one I measured both intake and exhaust push rods at the completely closed position on both TDC and on over lap(180 degrees from TDC) and they both measured within 2/32 inch from TDC to overlap. I don't understand why that matters?
Old Jul 1, 2019 | 12:59 AM
  #310
xlt4wd90's Avatar
xlt4wd90
The most important thing about adjusting rocker preload is to make sure that the valve is closed when you do it. Otherwise, it doesn't matter what part of the cycle the piston is at. It's just convenient to get both valves of a cylinder closed so you can adjust them both at the same time. There's nothing that says you have to do that; you can adjust just the one closed valve on a cylinder, regardless of how the other valve is at the moment.
Old Jul 1, 2019 | 02:19 PM
  #311
BeauF0RD's Avatar
BeauF0RD
I get my crane cam shims tomorrow, I'm going to try to get all valves to be torqued by 1/3 rotation with torque wrench. I guess this is suppose to increase H.P. slightly.
Old Jul 1, 2019 | 08:30 PM
  #312
xlt4wd90's Avatar
xlt4wd90
You want to set the lifter preload to about 0.03". That is, once you've torqued the rocker bolt to spec, the pushrod should have pushed into the lifter plunger about 0.03". If it's more, you can reduce it by installing a shim under the pedestal. If it's less, you will need to order longer pushrods.
If the preload is to much, valve may not fully close when it should, so the cylinder can not build as much pressure as it normally should. Worse, if the valves don't close completely, their faces may be burned.
If the preload is too little, or if you find clearance between the parts, you need to order longer pushrods. In this case, you might want to get a pushrod length checker to find the exact length you need.
Neither situation should be run at all regardless of their effects on HP.
Old Jul 1, 2019 | 09:32 PM
  #313
BeauF0RD's Avatar
BeauF0RD
So does turning the torque wrench 1/3 rotation, if it reaches the preset torque value of 22 ft. lbs. set the preload to 0.03?
Old Jul 1, 2019 | 10:57 PM
  #314
xlt4wd90's Avatar
xlt4wd90
I don't know about that 1/3 rotation, or where that trick comes from. I take measurements using a dial gauge on the pushrod oil hole of the rocker arm from the point where clearance is taken up to the point where I achieve 22 lb-ft of torque on the bolt. If it's more than .03", I add shims until it gets there. I never counted how many turns of the bolt it took to get from no-clearance to 22 lb-ft torque. But that would be a dead-reckoning method that would only work if all the components were exactly the same. The fact that we have to use shims sometimes tells us that there are enough variations that need to be compensated for.
Old Jul 1, 2019 | 11:13 PM
  #315
BeauF0RD's Avatar
BeauF0RD
It's amazing how many different methods are used just simply tightening pedestal rockers. The method i'm using was explained to me by the Ford racing tech line guy, I'll do it this way and see how it works out, if it doen't work I'll try something different. I just want to say thanks again to you guys for all the technical help you have given me these last two years.
