302 engine issues.
Old Sep 30, 2017 | 11:25 AM
  #76
KULTULZ's Avatar
KULTULZ
Post
Originally Posted by BeauF0RD
Ngk or autolite spark plugs? My last two sets were autolite copper 26 but I'm thinking about trying out the ngk copper 26 for my 302.
Well, both are good brands. I would go with whichever is cheaper right now until you get everything dialed in correctly, than maybe a fresh set of MOTORCRAFT copper.
Old Oct 1, 2017 | 09:25 AM
  #77
Mudsport96's Avatar
Mudsport96
I run autolite coppers and change them every 50,000 or so. Haven't had any problems so far.
Old Oct 13, 2017 | 08:56 PM
  #78
BeauF0RD's Avatar
BeauF0RD
Friday report, I have been doing a lot of back road driving and diagnosing the last two weeks. I had a hesitation when I would romp on the throttle but today we did some adjusting on the accelerator pump and the hesitation is gone. However we are not getting the 4 barrel to kick in. I have ordered a new vacuum secondary diaphragm, new spring kit and a quick change top cover (PN 20-59). Hopefully this will help with getting the carbs.full power potential.
Old Oct 13, 2017 | 09:38 PM
  #79
BeauF0RD's Avatar
BeauF0RD
Picture of my 1976 F-100 that you all have been helping me with.
Old Oct 14, 2017 | 01:32 AM
  #80
xlt4wd90's Avatar
xlt4wd90
How do you know the secondaries aren't opening?
Have you tried manually opening them? You need to open the primaries first before trying to open the secondary. It's good to at least check to make sure no linkages are jammed.
Old Oct 14, 2017 | 08:21 AM
  #81
richter roxs's Avatar
richter roxs
Nice ride, love the paint . Good luck
Old Oct 14, 2017 | 09:32 AM
  #82
Mudsport96's Avatar
Mudsport96
Sorry no idea how to tune a Holley. I'm a quadrajet guy.
Old Oct 20, 2017 | 04:55 PM
  #83
BeauF0RD's Avatar
BeauF0RD
Friday report, So I got my new parts, a secondary diaphragm, a spring kit and a quick top. When we took the carburetor apart we discovered the diaphragm that was in the carburetor was good but replaced it any how since I already bought the new one. I love the new quick top, it makes changing out springs a breeze. My carburetor had the heaviest spring in it, black, and that was the problem why the secondaries were not kicking in. After running and changing numerous springs we ended up with the long yellow spring that gave us a good smooth power surge. I believe the carburetor is finally as good as we can make it with what we have available. I will drive it as is until I can afford to get true dual exhaust with headers and that may be a few months down the road. Thanks again for everybody's help and a happy ending.
Old Mar 29, 2018 | 12:03 AM
  #84
Charles Espenshade's Avatar
Charles Espenshade
Are you running a computer?
Originally Posted by baddad457
To address the backfiring, check the accelerator pump linkage, there should be little to no slack in the linkage, too much and that'll cause a lag in the pump shot, causing the backfire. Too little timing will also do this. Also I wouldn't worry about the mechanical advance inside the distributor until you have dialed everything else in. I'm running a stock reman 85 Stang distributor as is, right out of the box in my 331. I've found no need to screw with the mech advance weights or springs. The motor runs like it has EFI with it's 3x2 setup and stock Duraspark. Last time I checked it would pull down 16 mpg at 70 mph without overdrive (turning around 3 grand). And you change springs and weights you'll need to find someway to verify the results (dyno or passes at the track), otherwise you'll be shooting in the dark.
I'm building a '85 302. I was thinking on using stock distributor. Someone told me how to wire without using a computer.
Now for the timing issue. The Crane Cam I'm installing says it will change the firing order. It's a 478 lift, 284 duration. I contacted Crane and the gentleman who I spoke with informed me of it.
I'm building a little playtoy. It's a '89 Ranger Kingcab. My block is bored 30 over and decked 15 thousandth. My head's are stock besides being shaved 8 thousandth. No timing chain in this motor, straight gears. Have a little Motorcraft built by Holley carb, think it's just a little 600 cfm.
I'm hoping to get 375-400 hp out of it. Any little hints you could give me about the carb? It does need rebuilt but I'm just holding off for now. Any certain power valve you would recommend? I was thinking on jetting it up a little, maybe close to 650 cfm.
Old Mar 29, 2018 | 02:50 AM
  #85
baddad457's Avatar
baddad457
That's a poor choice of a carb. It's an an emissions carb and little you can do to fix that. And then there's your wanting to "jet it up to 650 cfm". That is impossible. Rejetting it only changes the air fuel ratio. It does not increase the cfm rating. Third is your using an 85 block, then decking it .015. That block had thin decks to start with(if it's truly an 85 block), now you're really asking for trouble with head gasket sealing. Ford added 4 lbs of iron to the 86-up blocks in the deck area to stiffen them because of sealing issues. Now, before you go farther with this, get a book on carburators and read it. Bigger carbs are not better. The smaller they are the better they function. The vacuum generated by the engine under it is what draws the fuel into the throttle bores. making the bores bigger (choosing a bigger carb) isn't always the best thing to do with one.
Old Mar 29, 2018 | 07:24 AM
  #86
Mudsport96's Avatar
Mudsport96
On top of what baddad said, lose the gear drive setup. The tolerance required for meshing gears properly can cause fluctuation in your timing up to 4 degrees back and forth. Just get a quality timing chain.
Old Mar 29, 2018 | 04:51 PM
  #87
baddad457's Avatar
baddad457
Ditto on this ! I was in a hurry when I typed the previous post. There's absolutely no reason to run a gear drive for the cam. I've got a $25 O.E double row, roller chain set driving the cam in my 331 (Cloyes for a GT Stang) It's been doin it's job for 14 years now. I pulled the timing cover last year when I went into the motor to change a bent rod. Chain was still nice-n-tight.
Old Apr 22, 2018 | 08:42 PM
  #88
BeauF0RD's Avatar
BeauF0RD
Since this is a thread that I started I figured I would give a update. My 302 has been running great, I just installed a new power steering pump and two new belts.
Old Sep 1, 2018 | 02:31 PM
  #89
BeauF0RD's Avatar
BeauF0RD
Okay I'm back with another issue. I recently put new headers and exhaust on my 76 and I also replaced my spark plugs with a new set of autolite spark plugs since I had to remove the old ones to install the headers. I also replaced the carburetor base gasket with a 5/16 thick Holley gasket to help prevent any possible future heat soak issues with the carburetor from the header heat. Since I had the carburetor off I replaced my used and slightly bend accelerator pump arm with a new one. Now to my issue, when I lightly accelerate I have a hesitation in second and third gear. I already tightened down the accelerator pump arm spring more than I like with no good results. Any suggestions?
Old Sep 1, 2018 | 03:32 PM
  #90
BeauF0RD's Avatar
BeauF0RD
I'm thinking about changing my accelerator pump squirter from a 31 to a 35 just to see what kind of effect that will have?
