302 engine issues.
Old Mar 1, 2019 | 03:38 PM
  #256
stonesg's Avatar
stonesg
TWIN TURBOS!!!!
Oh wait... did I say that out loud???
Old Apr 8, 2019 | 08:33 PM
  #257
BeauF0RD's Avatar
BeauF0RD
I took the truck out for a drive today and I have a few questions. My truck was tuned and running very good in 32 degree temps. Today it was 77 degrees and my truck ran strong but I noticed some popping on deceleration and it felt like I had some minor surging at cruise. I checked my engine with a vacuum gauge in the garage and I have a steady 19. Could my choke setting cause these symptoms?
Old Apr 9, 2019 | 11:57 AM
  #258
baddad457's Avatar
baddad457
If you tuned it while the choke was engaged, yea. Once it warms up it'll lean out.
Old Apr 9, 2019 | 07:13 PM
  #259
BeauF0RD's Avatar
BeauF0RD
I did all the tuning at operating temperature, what else would cause surging at cruise?
Old Apr 9, 2019 | 08:57 PM
  #260
baddad457's Avatar
baddad457
I'd think you'd have a vacuum leak. What did you do with the transmission in it since this began ? I'm thinking you have an automatic in it right ? The modulator valve diaphragm may have ruptured with the spirited driving you mentioned.
Old Apr 10, 2019 | 08:24 PM
  #261
BeauF0RD's Avatar
BeauF0RD
I have a three speed manual on the floor. I will drive it again this weekend and see if I get the same results.
Old Apr 21, 2019 | 04:27 PM
  #262
BeauF0RD's Avatar
BeauF0RD
I have been driving the truck quite a bit since this post with pretty much the same results, the popping on deceleration is for the most part when the engine is cold, I will deal with it until I replace my choke. The surging is constant at low rpms, I think it would be considered the second transition and from what I read that would be the power valve. A while back a Holley tech talked me into changing my power valve from 6.5 to 9.5 to fix a hesitation since my truck has a steady 19 vacuum, it did fix my hesitation but maybe 9.5 is too big, I'm thinking this could possibly be the cause of my surging?
Old Apr 21, 2019 | 09:20 PM
  #263
Justin Jones's Avatar
Justin Jones
Power valve size is supposed to be: full operating temperature, slight load on the engine, take a full vacuum reading, half of that. A 9.5 is too much.
Old Apr 21, 2019 | 09:46 PM
  #264
baddad457's Avatar
baddad457
A 6.5 PV should be the one you need. What ignition are you running ? The surging could be caused by the ignition.
Old Apr 22, 2019 | 08:15 PM
  #265
BeauF0RD's Avatar
BeauF0RD
I still have the stock Duraspark ignition. With the 6.5 PV I had a hesitation, with the 9.5 PV I have surging. I will try something in the middle. I also went from 91 octane gas to 87 octane, non ethanol of course. Another change I recently did was the installation of a fuel pressure regulator to get fuel pressure from 10 psi to 7 psi.
Old Apr 22, 2019 | 08:45 PM
  #266
baddad457's Avatar
baddad457
Have you checked to see if the vacuum advance is working ?
Old Apr 22, 2019 | 08:53 PM
  #267
BeauF0RD's Avatar
BeauF0RD
I did a few months ago, everything was fine, I guess I could try again. Remove cap and look for rotor to move by applying pressure to hose right?
Old Apr 22, 2019 | 10:53 PM
  #268
baddad457's Avatar
baddad457
Not the rotor, the breaker plate under it. Could also be a bad spark box too.
Old Apr 23, 2019 | 08:39 PM
  #269
BeauF0RD's Avatar
BeauF0RD
Breaker plate, right. What is the spark box? Ignition?
Old Apr 23, 2019 | 09:02 PM
  #270
baddad457's Avatar
baddad457
It's the pot metal box connected to the distributor via a wiring harness.. When they first came out in the 70's they were notorious for failing muy pronto.
