302 engine issues.
Old Sep 18, 2017 | 06:23 PM
  #61
BeauF0RD's Avatar
BeauF0RD
Originally Posted by bsraborn
A few more thoughts as I think about this:
1) Already discussed, but I didn't see confirmation that you confirmed the integrity of your harmonic balancer. The "Positive Stop Method" would allow you to confirm when your piston is at TDC that your harmonic balancer is reading at TDC. If it has slipped then you are timing at the wrong spot.
2) In your initial post you mentioned timing was way advanced and once you retarded it, the backfiring and black smoke occurred. Have you tried running the timing up again just to see if that calms the backfiring?
3) Wondering if it's possible your dizzy is not advancing when you give it throttle. Can confirm with a timing light.
4) I think going to a smaller accelerator pump nozzle would exacerbate the problem. In my experience, stumbling off idle is because the engine isn't getting enough fuel for that transition from no load to load.
5) Spark is jumping to the wrong cylinder - possibly dist. cap or plug wires compromised.
6) If you have a smart phone and can post a video to YouTube with a link that would go a long way to help with diagnostics.
I know you've done a lot to confirm the timing, but going back to theory here the only way you can backfire through the carb is for the intake valve to be open when ignition occurs (someone correct me if this isn't the case - I think someone already said as much in the thread). I've seen others talk about a carb backfire under lean conditions but you clearly aren't running lean - I suspect this is because the engine is more susceptible to pre-ignition under lean conditions.
bsraborn, thanks for your very in depth response, I'm so impressed that you took the time to read through my thread to help me. I will have to read up on the "positive stop method", thanks. This last time we worked on the truck we spend much of our 2 hours just getting the carb back together and getting the tach operational which should be beneficial when trying to tune. This Friday we will be revisiting the timing and I am purchasing two new squirter nozzles, a 28 and a 35 to experiment. We put some type of vacuum pump on the dizzy and other various test showed that it is functioning. I am buying a timing light that has a dial so I can test total timing Friday that should give more answers as well. I have new spark wires with spacers and am sure I routed them correctly to avoid detination but you never know, maybe. And my neighbor believes the dist. cap is in good shape, maybe not. I have a smart phone and can record the engine but I don't know how to post on youtube, I never tried. I mentioned earlier about the loose valve #2 and us shimming it, this could be part of the trouble as well, especially since we didn't follow proper torque specs. I plan on revisiting this valve train issue soon. And finally your right about not looking like I'm running lean, the plugs are black and black smoke out the exhaust. It's a project truck, I have been studying and learning and enjoying everybody's help. It has been fun and I know eventually we will get it worked out. Thanks again to everyone.
Old Sep 21, 2017 | 11:49 AM
  #62
Mudsport96's Avatar
Mudsport96
I agree with posts 27 and 60. The balancer on my 95 302 LOOKS fine to the eye, but is actually off by almost 5 degrees. Definitely look up how to do the positive stop TDC test. Also, if you are using an adjustable timing light throw it away and get a standard one. The advance style leave much to be desired on accuracy.
Old Sep 22, 2017 | 09:01 PM
  #63
BeauF0RD's Avatar
BeauF0RD
It's time for my Friday report. My neighbor came today at 2 pm as always and he immediately said we need to start the engine and pull the spark plug wires off the spark plugs one at a time to see if we have any dead cylinders. It turns out there were several that when pulled there was no difference in the idle = dead cylinders. My current plugs were recently purchased Autolite copper 26 plugs, the part that screws into the block is chrome looking. The plugs that came with the truck were Autloite copper 26 with a black body that screws into the block. We replaced the new plugs with the old used plugs and the engine came to life, the idle was stronger, the vacuum came up, and when we blipped the throttle the backfire was gone ,that's huge. We did a little more dialing on the idle mixture screws and set the idle screw at 650 rpms and everything was sounding great and the vacuum steadied out at 19. We checked the timing and it is still set at 14 btdc, everything was still weirdly enough sounding good after weeks of frustration so we decided to take it out for a test run. We went on a couple mile drive and I'm pretty happy with the results, decent power and no backfires but there is a bit of hesitation when the throttle is given at times but thats minor and I think we will get that worked out next week as well. Thanks to everyone for all your interest and help, I'm very grateful to you all.
Old Sep 23, 2017 | 02:50 AM
  #64
xlt4wd90's Avatar
xlt4wd90
Congratulations on solving a mystery; it must feel good.
It's possible that your recent plugs got fouled from originally running too rich. This happened to one of my engines that had not been run for a long time. I tried to to clean them up by burning the build-up off with a blow torch. They worked better, but still not quite as good as new, never-fouled plugs.
Your hesitation with throttle opening may be due to your attempts to lean out the carb. Maybe you can replace the new squirter its original, larger version.
I assume that you replaced the pump diaphragm when you rebuilt the carb? One of mine had turned stiff, and did not squirt much as I opened the throttle, resulting in stumbles every time.
Old Sep 29, 2017 | 08:02 PM
  #65
BeauF0RD's Avatar
BeauF0RD
It's Friday and my neighbor and I worked on my truck. We hooked up the vacuum gauge and got busy, we first loosened up the distributor and advanced it to see how it would affect the vacuum and we were able to get the vacuum up to 21 but didn't like it advanced up beyond 14 btdc so backed it off a bit again to 14 btdc and played with the mixture screws and ended up with a very steady 20" vacuum reading and a 700 rpm at idle with my manual transmission. I have to say I'm very happy to have the engine running so well after all the frustration resulting from this change over. This truck is far from a hot rod but that didn't hinder my son and I from pretending that it was and having fun. I will let this thread fade out for now until I have more issues, thanks again for all the help.
Old Sep 29, 2017 | 08:40 PM
  #66
Tedster9's Avatar
Tedster9
Sounds good! Remember the vacuum reading is a true indication in this situation, without going over the last 2 pages, the suspicion is that the damper is lunched iirc, right?.
So in this situation the "14°" indicated on the damper is pretty much useless if that's the case, and should not be relied upon as the basis for deciding how much initial timing to dial in. Although 20" of vacuum at idle is right in there where you want it, and 14° sounds about where it would be.
The important thing is to see where the timing is at 3000 or so, where does it end up advancing, maybe 34° or 36° without vacuum advance connected. That's the key, the initial timing doesn't really matter too much. Set the initial wherever it needs to be to get there, once you have a damper that is known accurate.
Sent from my iPhone using IB AutoGroup
Old Sep 30, 2017 | 09:05 AM
  #67
BeauF0RD's Avatar
BeauF0RD
Tedster9, I'm not sure where you got the idea that my damper (harmonic balancer) Is lunch? maybe confused with another one of the many threads you contribute to? thanks by the way. I believe the damper is good to go but I still did not try to rev the engine to 3000 rpm to get total timing. I will do that and report back with the results. But again all is well for now and I'm happy with how the truck is presently running.
Old Sep 30, 2017 | 10:37 AM
  #68
KULTULZ's Avatar
KULTULZ
Question
Originally Posted by caly350
I always giggle at the "one tooth off" comment regarding a distributor install......there's no such thing.
Why do you think that? Just wondering.
Old Sep 30, 2017 | 10:44 AM
  #69
KULTULZ's Avatar
KULTULZ
Smile
The hell it doesn't. If the distributor is stabbed "a tooth off", or more from where it was the engine timing will be way off. It may not even run. It's a very common error and can cause a lot of head scratching, that's all. We're in agreement.
Take it easy Ted. We both know you are correct. There is a lot of mis-information posted here and all one can do is post correct info and hope the OP goes that way.
Oh, a lean condition (such as accelerator pump operation/adjustment) can lead to a lean backfire.
Old Sep 30, 2017 | 10:47 AM
  #70
KULTULZ's Avatar
KULTULZ
Exclamation
Originally Posted by BeauF0RD
My neighbor said there is no torque limit on tightening the rockers, so he cranked them all down with all his strength.
...sigh...
So over torquing a fastener and stretching its' threads and its torque holding ability is an accepted method?
Goes along with the BFH and HOT WRENCH way of doing things...
Old Sep 30, 2017 | 10:55 AM
  #71
BeauF0RD's Avatar
BeauF0RD
Originally Posted by KULTULZ
...sigh...
I'm sure you are right, but regardless the truck is running pretty good for now so I will enjoy it until I need to go back into the valve train and will be sure to get the proper torque and sequence done at that time.
Old Sep 30, 2017 | 11:04 AM
  #72
KULTULZ's Avatar
KULTULZ
Post
Let me point out two things.
1) You need to re-check the inline fuel filter install
2) and a carbon fouled plug ain't gonna fire with a stock IGN.
No reply necessary unless you want to scold me...
Old Sep 30, 2017 | 11:09 AM
  #73
BeauF0RD's Avatar
BeauF0RD
KULTULZ, I will only thank you not scold you. I'm always welcoming of peoples help and suggestions.
Old Sep 30, 2017 | 11:12 AM
  #74
BeauF0RD's Avatar
BeauF0RD
Ngk or autolite spark plugs? My last two sets were autolite copper 26 but I'm thinking about trying out the ngk copper 26 for my 302.
Old Sep 30, 2017 | 11:18 AM
  #75
KULTULZ's Avatar
KULTULZ
IMO
Another thing and I will be brief as I try to avoid on-line food fights...
Timing is everything. A balancer has to be verified as correct before any engine modifications are attempted, otherwise you will be beating your head (and wallet) against the wall.
Proper indexing is done with a piston stop, period. No coat hangers, no I think the valves are closed. If bad, you have that balancer rebuilt with an elastomizer and indexed correctly. You then have it pinned (I know, this is not a race car) to assure future integrity.
Then IGN and valve-train timing events can be be ascertained accurately. You also need to check at this point timing chain stretch/variance.
Concerning carbonation... ... carburetion...
There is no one fits-all carb. It needs to be dialed into the vehicle (not just engine). That TECH BOOK will get you started.
The HOLLEY WEBSITE has tons of info.
All of the above is IMO and your mileage may vary.
No reply needed unless I posted something incorrect and/or p!ssed someone off....
