Changing the transmission filter
Old Sep 8, 2016 | 08:15 AM
  #226
TooManyToys.'s Avatar
TooManyToys.
Scott, not sure being here would have helped me being an only child. I'm hoping for one or two degrees cooler wth the deeper pan and more fluid.
Old Sep 8, 2016 | 08:05 PM
  #227
04badford's Avatar
04badford
What's everybody temps looking like? Post OEM com paired to. New pan , ready go................................................ ................
Old Sep 8, 2016 | 08:27 PM
  #228
TooManyToys.
No reason not to be the same.
Old Sep 9, 2016 | 11:30 AM
  #229
diesel_dan's Avatar
diesel_dan
You know, if you haven't got the pan installed yet, you could have a shop weld on some cooling fins. As I understand it, if you make them in the shape of the old Caddy rear tail fins, your truck will not only be faster, it will track straighter, and at least "look" cooler
Plus you would earn an honorary spot in the "ridiculous Stacks" thread just for being so dang cool...
Old Sep 9, 2016 | 12:27 PM
  #230
TooManyToys.
I'm having visions .....
Old Sep 9, 2016 | 12:34 PM
  #231
diesel_dan's Avatar
diesel_dan
Now, that there is a bolt on mod -- you'll need 4 of those for the trans and one for the oil pan. Optionally you can mount one to your FICM for enhanced cooling and glue one to the degas tank, which also will help keep your coolant temps in check.
and:
Old Sep 10, 2016 | 06:32 PM
  #232
jobberone's Avatar
jobberone
Ok, as I told a very nice gentleman who sent a message, I enjoyed the thread and all the thread was useful to me.
Now I have another question.
I found this in the bottom of the pan:
So where does it come from, how do I get it back where it belongs, and if I can't find where it goes and replace it, can I pull a load safely and get where I'm going?
Old Sep 10, 2016 | 06:34 PM
  #233
r2millers's Avatar
r2millers
and:
Ya, this fins worked pretty well. Never had my YZ400 or YZ465 Yamaha's ever overheat and seize a piston while desert racing at some pretty warm temps.
They work well as long as your moving, hence the reason here in CA motorcycles can drive between cars. Now, most bikes are water cooled but not back in the day. Still many on the road.
Old Sep 10, 2016 | 06:42 PM
  #234
r2millers's Avatar
r2millers
Kinda looks like a clip that wraps over a stationary position to hold a wiring harness in place? Just a guess but will be interesting to see the correct answer.
Old Sep 11, 2016 | 02:40 AM
  #235
Yahiko's Avatar
Yahiko
Mark Kovalsky
Where are you?
You know having pulled a 5R110W all the way down that part does not look familiar.
Sean <BR>
6.0L Tech Folder
Old Sep 11, 2016 | 06:10 AM
  #236
jobberone's Avatar
jobberone
Originally Posted by Yahiko
Mark Kovalsky
Where are you?
Sean <BR>
6.0L Tech Folder
I'm in the South and I have no idea what that part is. It was laying in the pan as I pulled the 6.0 L pan preparing to install the big filter and pan.
Old Sep 11, 2016 | 06:53 AM
  #237
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Mark Kovalsky
Where are you?
Sean <BR>
6.0L Tech Folder
I don't recognize it.
Old Sep 11, 2016 | 07:04 AM
  #238
jobberone's Avatar
jobberone
I understand but it didn't climb in there itself. I don't THINK it is critical but I know little.
Thanks tho!
Anyone else??
Old Sep 11, 2016 | 08:05 AM
  #239
TooManyToys.
I looked at the pictures I took of the open transmission and see nothing like this.
The far end of the clip in the picture, is that end fractured or was it a machined cut?
Old Sep 11, 2016 | 09:02 AM
  #240
jobberone's Avatar
jobberone
I think it has been fractured. Good question.
