Changing the transmission filter
#121
Got home today and found that the pan with reusable gasket has a drip. Only fix is to remove the pan and check the mating surface for flatness. The gasket with the new pan isn't as good as the old gasket, it's just a flat prices of rubber and at 11lbs is squeezed so that's it's bulged at the screws in several locations.... the location of the drip.
The old gasket is rubber with a good wire frame sandwiched between the sealing material.... it's going back in. The real bummer is that I'm going to dump $40 worth of fluid in the can at Advance!
Why don't you drain it into a new clean pan and dump it back in after gasket swap?
#122
#123
I always keep one or two new paint mixing plastic buckets
around just for that type of thing. When they start to show
there age then they get tossed after cleaning so I don't have
the recycle person mad at me for the oil.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#126
the new pan included a new gasket, not as good as the old one and upon reuse, seems to have degraded. I'll pick up a HD bucket today... I just hate trying to hold that bucket and dipping ...... Harbor Freight just opened a new place down the street, hand pump for $5... I like excuses for a new tools!
That should answer the question about Wolf's Head brand. You'll need 9 quarts.
#127
Some have said a new Ford trans pan does not include the gasket. Was this gasket in the Ford box, and if not where did you get the pan from that included this separate gasket.
The OE gasket, F6TZ7A191A, is not an inexpensive gasket. The aftermarket versions, even from FelPro are 1/2 to 1/3 the price of the Motorcraft part, so if this was a Ford supplied gasket it's disconcerting to know the product is not as good as the assembly line product.
#128
You have to remember, I bought my pan and filter December 2014 and installed Jan 2015. When Money-Pit did the first thread on this way back. I purchased the entire set-up from Tousley Ford, the gasket was included in the box. It looks like a plain jane rubber gasket from flat stock 1/8" rubber material that was stamped to the shape of the pan and holed with a punch. It does fit perfectly, but, when I tighten the bolts to 11lbs, the material now has been squeezed and is protruding from the area between the mating surfaces. Its as if it's been broken down by the fluid over time.... and probably has.
The old gasket, the OEM gasket that I removed with the old pan is wire framed and rubber coated, will not deform with the torque when tightened I'm sure. I'll snap a photo this afternoon for everybody to see.
I'd bet they supplied an aftermarket gasket...received numerous complaints and stopped supplying one with the pan.
#129
#130
#132
I installed it with the new pan because it came with the new pan... figured I'd give it a try and had no issues until I re-installed. I did keep the OE gasket knowing it was a better gasket, but didn't have any issue, so I left it alone. Bit me yesterday... besides, I like doing jobs twice
I'll take a picture of the old pan and gasket and the new pan and cheap gasket for comparison today for all to see...to help everybody.
#133
Old is 4.75"
New 08 pan is 5.00"
#134
#135
In discussions we've had here before on SP or LV or does this other fluid meet the spec, one thing we have split hairs over, is when a product says it "meets or exceeds XXX spec", versus saying: "designed", or: "engineered" "to meet the spec of XXX" -- which many have said is like saying we've made an attempt, but we haven't actually gotten it approved, or tested (or paid the license fee, whatever).
So, it is your transmission and each person's own decision, but for me personally and because our Torqshifts can be picky about the fluid, I'd only run a fluid that specifically states it Meets Mercon SP or LV specifications.
My $.02 worth and I just thought I'd put it out there to you, and take it for what it is worth (which on the internet is likely zero ).
All the best,
Scott
