External fuel pump
Old Jul 21, 2016 | 03:25 PM
  #556
vjsimone's Avatar
vjsimone
Originally Posted by Gary Lewis
I would be surprised if the test light will power the solenoid.
It did not, so I had him move to a jumper wire. It depends on the test lamp, I have one that works.
Old Jul 21, 2016 | 03:29 PM
  #557
Gary Lewis's Avatar
Gary Lewis
Yes, it depends on the test light. And some are using LED's as test lights.
Old Jul 21, 2016 | 04:02 PM
  #558
ctubutis's Avatar
ctubutis
Originally Posted by Festus Hagen
I gotta say ...
Steve, This has been a long challenging and complicated thread ... You have hung right in there like a champ, got a little frustrated/confused for a bit, but recovered awesomely ... I am impressed!
Bill, Vincent, Hats off for sticking it out ... That's Sticktoitiveness!
Kudos to all ...
-Enjoy
fh : )_~
I agree, thank you for being vocal about it, Festus!
The thing that struck me the other day was when Vincent (?) said something like, "Go back 200(!) posts and look at the wiring diagram."
This has been a long one, thank you to Vincent & subford & everybody else for sticking with the guy.
Old Jul 21, 2016 | 04:16 PM
  #559
vjsimone's Avatar
vjsimone
Originally Posted by vjsimone
I'm going to have Steve test some things;
a. 12 vdc on both sides of the EGRV connector? (With key on)
he has 12v both sides.
b. Disconnect connector, check resistance of the coil, I usually get anywhere from 40-75 Ohms.
he has 43ohms.
c. Use his jumper to ground the ECA side of the EGRC connector to turn on the solenoid and look for vacuum at the gage. (Key on & engine running)
Solenoid’s works both ways. no vacuum at the EGR.
d. Remove black hose at the reservoir to check for source vacuum.
20Hg on the red hose coming from the manifold.
Nothing on the other side of the reservoir. (Blocked)
he unblocked the reservoir. Still no vacuum at the EGR.
He found a leak on the manifold feeding the vacuum to the solenoids.
We have stopped here. Good luck fixing that…..
So I gave him a few ideas to fix the leak, but told him to block the source vacuum at the reservoir for now.
Old Jul 21, 2016 | 04:17 PM
  #560
vjsimone's Avatar
vjsimone
Good point, mine is old, his is new.
Old Jul 21, 2016 | 04:47 PM
  #561
vjsimone's Avatar
vjsimone
So, that did save a lot of typing…. And Steve was running back and forth between the garage and house to get updates off the computer, he must be fast….
He has to fix; Vacuum leak at the vacuum manifold & O2 sensor, and, I forgot, there is the rainy day issue that started with post #1.....
He did not have vacuum to the EGR during the self-test, nor did he have it when he was accelerating (no wonder he said he had so much power) The Self-Test was looking for the idle to drop when it opened the EGR Valve, and it did not so it threw a Code 34.
The manifold vacuum leak did not affect his idle or O2 Sensor because the reservoir was clogged. He blew it out, but maybe too much air pressure, we will see.
Do I think everything we did over the phone was perfect, of course not, and may have to be re-visited?
he has 43ohms.
Old Jul 21, 2016 | 05:25 PM
  #562
sgauvry's Avatar
sgauvry
I'm a stubborn cuss. Watch me! lol
Good luck fixing that…..[/QUOTE]
Old Jul 21, 2016 | 05:29 PM
  #563
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Anybody got a good picture of this leaky vacuum manifold?
Preferably off truck & unhooked so it's real visible.
-Enjoy
fh : )_~
Old Jul 21, 2016 | 05:50 PM
  #564
Gary Lewis's Avatar
Gary Lewis
This one has been a marathon, and all are to be commended. However, Steve and Vincent deserve the lion's share of the commendation. Steve has not only stuck with it, but has also stayed on target. And Vincent has been a true hero.
But, I'd like to point out something else that has helped - that most of the rest of us kept from sidetracking either Steve or Vincent. (Or, maybe I should say most of you did, as I did sidetrack things once or twice.) Too many times I/we jump in to "help", but adding to the number of cooks in the kitchen rarely helps. Instead, and I'm preaching to me, we need to let someone take the lead and only chime in when we feel there's an error.
Well done, Vincent!
Well done, Steve!
Old Jul 21, 2016 | 07:12 PM
  #565
vjsimone's Avatar
vjsimone
Well, I have been sucking info off this Forum since 2013, so I am glad when I can give back. I learn all the way through, and thanks to everyone for supporting with knowledge and products. Thanks for keeping me straight, and questioning me, always welcome, I'm surely far from perfect. I have had the luxury of helping a few friends with their Fords along the way, and one happens to be in my signature, which has given me an edge on this 85’ thread.
I head out of town in a week for 3 months, but I will check in when I can……
Steve, if you have any new issues, not previously covered, please start a brand new thread. We could have made 4 separate threads out of your issues……… We can keep the EGR, O2 & Rainy day on this thread..
We’re trending….. Over 6K views & over 500 post, like Gary said, Marathon.
Old Jul 21, 2016 | 07:25 PM
  #566
Gary Lewis's Avatar
Gary Lewis
Three months? Where to?
Old Jul 21, 2016 | 07:41 PM
  #567
vjsimone's Avatar
vjsimone
My secret safe house in Mall Bay, Newfoundland Canada..... would have been there by now, but my knee surgary has held me back....
Old Jul 21, 2016 | 09:17 PM
  #568
Gary Lewis's Avatar
Gary Lewis
Sounds good! Gotta be warm and humid in Virginia right now.
Old Jul 21, 2016 | 09:23 PM
  #569
vjsimone's Avatar
vjsimone
Miserable…….Never left thehouse today... Lucky Steve
Old Jul 22, 2016 | 06:38 AM
  #570
c2z4s9's Avatar
c2z4s9
He has to fix; Vacuum leak at the manifold & O2 sensor, and, I forgot, there is the rainy day issue that started with post #1.....
So does that mean he's cleared his code 34? I think he said he cleared 13 also by following your procedure to reset the idle. That leaves 41 (i think). This is an O2 sensor; system reporting lean?
