External fuel pump
Old Jul 22, 2016 | 02:06 PM
  #601
sgauvry's Avatar
sgauvry
Good question, Gary. Let me check.
Originally Posted by Gary Lewis
No numbers visible?
Old Jul 22, 2016 | 02:08 PM
  #602
c2z4s9's Avatar
c2z4s9
Originally Posted by sgauvry
Here a pic of one laying on the back side, and going from side to side. Note the two little inlets to the upper center (left) of the unit.
I also have this thing he is describing, I think. I can try to take a picture of it later.
Old Jul 22, 2016 | 02:09 PM
  #603
sgauvry's Avatar
sgauvry
E5TE-9E453-AC
No numbers visible?
Old Jul 22, 2016 | 02:14 PM
  #604
Gary Lewis's Avatar
Gary Lewis
Bingo! E5TE 9E453-AC is the identification # for part # E5TZ 9E453-B.
  #605
sgauvry's Avatar
sgauvry
Here's a better pic of one upside down. The bolts go through the wheel well.
No numbers visible?
Old Jul 22, 2016 | 02:16 PM
  #606
c2z4s9's Avatar
c2z4s9
I think it was designed to cover the hoses, etc and be a vacuum reservoir.
Old Jul 22, 2016 | 02:19 PM
  #607
Gary Lewis's Avatar
Gary Lewis
Those are new to me. And, Ford's master parts catalog does not have an illustration for it in an '85 F-series.
Old Jul 22, 2016 | 02:31 PM
  #608
sgauvry's Avatar
sgauvry
May be. It may be it was designed to cover the solenoids.
Old Jul 22, 2016 | 04:45 PM
  #609
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Yes, that is peculiar to the 1985.5 and 1986 EFI 5.0L system.
Old Jul 22, 2016 | 06:43 PM
  #610
sgauvry's Avatar
sgauvry
Happy I can share something (finally) that I know a little something about!
Old Jul 22, 2016 | 07:03 PM
  #611
c2z4s9's Avatar
c2z4s9
Sqauvry, do you also have a little black death star vacuum reservoir? I have both the one you show and a death star; they are right next to each other. I'm not sure if this was stock or added after.
Old Jul 22, 2016 | 09:01 PM
  #612
sgauvry's Avatar
sgauvry
I do not. Question for you though: Is it your "death star" that is in use or the original?
Old Jul 22, 2016 | 10:26 PM
  #613
vjsimone's Avatar
vjsimone
Original ID/N E5TE-9E453-AC, this part has a check valve built into the reservoir. So if Steve blew high pressure into the Intake manifold side of the reservoir, he most likely popped the check valve diaphram.
He can put an inline check valve in the right direction, attached to the “Red” hose to fix this issue.
Old Jul 22, 2016 | 10:44 PM
  #614
vjsimone's Avatar
vjsimone
Vincent -
The new O2 sensor is in. I grounded very near the sensor to the exhaust flange that connects on of the headers to a pipe, and to the frame. I filed the frame to ensure good contact. Reading is a constant .2.
Codes are still 41 and 34. I'm going to take it for a ride and test again. I'll let you know if the results change.
By the way, if you remember there are two hoses that connect to the vacuum reservoir, one red, one black. Can't remember if we determined yesterday if there is suction in the red hose. There is plenty of suction. I tested it.
I can hear the replies now...
Steve
Yes, the "Red" hose has the vacuum on it, it leads to the intake manifold vacuum cluster via the Quad vacuum coupler just to the bottom right of the Reservoir/Solenoid cluster in question.
The “Red” hose goes to the taller plastic port/hose connection on the Reservoir. Normally you can suck on that tit, but you cannot blow into it.
You could put an in-line check valve in the right direction, attached to the “Red” hose to fix this issue. They are available via any auto parts shop. You just need that valve, and 1 piece of hose to make it fit.
Old Jul 22, 2016 | 10:52 PM
  #615
vjsimone's Avatar
vjsimone
Originally Posted by subford
CM codes do not clear so you must be talking about the KOEO or KOER code 34:
Service Code 34 in Key On Engine Off or Engine Running Self-Test indicates that the EGR valve and/or EGR Valve Position (EVP) sensor may not be fully seated in the closed position. The EVP sensor voltage is greater than the closed limit voltage of 0.67 volts. Because of the preload on the installed EVP sensor, it is very difficult to determine whether the EGR valve is seated or the EVP sensor is in contact with the EGR valve stem.
Possible causes:
-- Poor continuity in EVP sensor harness.
-- Non-seated EGR valve.
-- Damaged EGR valve.
-- Damaged EVP sensor.
-- Damaged EVR solenoid.
-- Damaged processor.
His current Code 34 issue is that he has no vacuum to the EGR during the KOER Self-Test.
