External fuel pump
Old Jul 14, 2016 | 08:37 AM
  #196
sgauvry's Avatar
sgauvry
OK. I'm going to follow-through and spray some cleaner into each connector and use deelectric grease. Not sure to go from there. If I have the wrong ECM after following the information Gary sent, how do I get the right one? The one I purchased has part number 78426 whcih covers #E5TF12A650SA, E5TF12A650SB, E5TZ12A650SA, E5TZ12A650SB.
Originally Posted by vjsimone
Ok, thats good, no shorts to ground. Providing you disconnected the Pos battery cable.
Old Jul 14, 2016 | 08:38 AM
  #197
vjsimone's Avatar
vjsimone
If you have the cash, an original 85' ECA may be another avenue......
http://car-part.com/
Used, Junk Yard ECA's; Car-Part.com--Used Auto Parts Market
Part Search; Select Part = "Engine Computer"
Search by year.
Suggest you order a xxx = "S1B".
E5TF-12A650-S1B
Old Jul 14, 2016 | 08:47 AM
  #198
vjsimone's Avatar
vjsimone
Seems to me another guy last month ordered the same computer, and cannot perform the self-test.
Old Jul 14, 2016 | 08:50 AM
  #199
vjsimone's Avatar
vjsimone
I think your rainy day issue may be solved by cleaning and greasing all your connectors.
Old Jul 14, 2016 | 09:10 AM
  #200
subford's Avatar
subford
If not too late maybe this will help:
Old Jul 14, 2016 | 09:48 AM
  #201
sgauvry's Avatar
sgauvry
OK. All connectors are cleaned and greased including connectors to sensors. I also saw that there's a boot (drain) that empty's directly onto a plug connector that connects to the external fuel pump. Don't know if that was the issue regarding the pump issues, but I cleaned that connector and greased it up as well. Will have to wait until another rain (probable today) to see if the fuel pump/injector engagement issue has been cleared up. Or, I could just hose everything down again and test it out, which I'll likely do.
Seems you're leaning to the ECM as the problem with regard to pulling codes. Since the 85 second half of the year was the first EFI for the F150, would you recommend I search by the year 1986, or doesn't it matter?
Search by year.
E5TF-12A650-S1B
Old Jul 14, 2016 | 10:00 AM
  #202
subford's Avatar
subford
Note the "B" (E5TF-12A650-S1B) is a revision code.
So maybe if you got a E5TF-12A650-S1C or E5TF-12A650-S1D if they exist might be a better computer.
Old Jul 14, 2016 | 10:02 AM
  #203
sgauvry's Avatar
sgauvry
So I'm a novice at this so please don't take offense to my question. Why would it be a better computer?
Old Jul 14, 2016 | 10:04 AM
  #204
Gary Lewis's Avatar
Gary Lewis
My catalog shows no E5TF-12A650-S1C, but there is an E8TF-12A650-S1C. And no 12A650-S1D of any year.
Were maybe codes not done in the early versions?
Old Jul 14, 2016 | 10:08 AM
  #205
sgauvry's Avatar
sgauvry
Hi Gary -
Are you saying I could go with the E8TF-12A650-S1C? The one I recently ordered form RockAuto was in this range #E5TF12A650SA, E5TF12A650SB, E5TZ12A650SA, E5TZ12A650SB. I also have a C6 tranny. Does that enter into the equation?
Old Jul 14, 2016 | 10:11 AM
  #206
Gary Lewis's Avatar
Gary Lewis
No, I'm not saying that. Not at all since I've not looked to see what that fits. It is 3 years later, meaning 1988, so may not even be close to yours.
All I was saying is that there is no -S1C or S1D for your truck, meaning no revision C or D.
Old Jul 14, 2016 | 10:14 AM
  #207
Gary Lewis's Avatar
Gary Lewis
UPDATE: E8TF 12A650-S1A, S2A.S, 1C, or S2C are for a 1988 Ranger, meaning a little truck, with a 6 cyl 177 cube engine. Not likely to work very well on yours.
  #208
sgauvry's Avatar
sgauvry
Thanks, Gary. I think I found one on Car-Part.com, E5TF-12A650-S1B,101558,JRG. Must I be concerned about the tranny being a C6.
Old Jul 14, 2016 | 10:59 AM
  #209
Gary Lewis's Avatar
Gary Lewis
Sorry, but I don't understand the question. Didn't you order and install a new ECM with the same #?
Old Jul 14, 2016 | 12:36 PM
  #210
sgauvry's Avatar
sgauvry
Yes, except the 101558,JRG numbers/letters confused me. What do they signify?
