Debugging slightly low boost
I need to make a glow plug insertion tool and a glow plug adapter tool.
I have a good 40 amp battery charger (for the compression test).
I know I need to turn the engine over with the keys out of the ignition for the compression test. I don't have a relay on the fender (2002 Excursion).
I think this yellow wire goes to a relay on the starter:
Can anyone confirm/deny?
I see a yellow wire in the harness with the big red battery wire. Then this wire seems to go down in that general direction. I can't see the spot where the wires are joined though.
That way it'll crank but not fire. That's how we did a 7.3L compression test Monday eve. Except for confirming a bad cylinder (ouch!), the test itself went well.
Sure, if that works. When i was reading up I got a loud and clear message - no key in the ignition....
It seems like most people jumper the relay on the passenger side fender well.
Hmmmm, I thought of one more reason for the jumper approach. If there's just one person doing the job you kind of need to watch the gauge while the engine is turning over.....
I guess I could rig up a gopro camera or cell phone to record the gauge and turn the engine over from the cab.
Just be careful of all the moving parts while testing
IIRC, you want to see 400psi, give or take. Better to be consistent between all cylinders that a specific target number.
Also listen for puffs (put a good glowplug back in the empty holes you aren't testing), which helps test leaking valves and such.
One other caution- shouldn't be an issue- make SURE no oil is near the glowplug hole before removing it. You do NOT want any oil in the cylinder
Have you done a compression test on an engine before? If not, I'd recommend doing the driver's side first. It's a bit easier to get to things.
Good luck
I seem to recall people saying to pull all the GPs because it will make the cranking go easier. You're saying to not do that?
The oil coming out of the injectors, is that driven by the solenoid, so it won't squirt oil if there's no power?
Thanks for the heads up. I'll do the driver side first, rear passenger side last.
Intake and exhaust valves open and close during intake, compression, fire, and exhaust strokes. That we all know
It is during the compression stroke you want to listen closely. I've found it helpful to be just off to the side of the engine to hear better and not be "blinded" by the starter and such.
During this stroke, if you hear blowby, a puff of air, etc, it could indicate a leaking valve (not closed all the way, not enough, carbon, damage, etc).
Really, you're listening for anything that sounds unusual to investigate further
GPs are up higher on the engine and *shouldn't* get oil in them. When you first open up the valve cover, there may be oil laying in there. It's not hard to avoid, and it's always a good idea to think about oil in the cylinders
Removing GPs...
If you have a GP removed and are not testing that cylinder, the noise of air coming out of that cylinder will likely obscure any other sounds and blow it towards you.
For easier cranking? Not sure why
You're only cranking a few seconds on each cylinder, so not really a concern, IMHO. But I'd listen to other opinions, always willing to learn
Blowing out the area with air...
Might want to do that before removing the valve covers, too. Make sure there isn't anything loose or laying on the engine that might get into the works when removed.
I like to inspect the rocker arms and any exposed parts for signs of wear, wiggle a little to make sure they are "happy" staying centered on top of the springs, etc.
And specific to these 7.3s, each time I've been present while one was opened, we've found *something* under the cover. Piece of plastic zip tie, piece of UVCH plug, etc. A flashlight and headlamp are helpful. Take a few moments to look things over.
A note: There are quite a few on here who have a LOT more experience with compression tests and specifically with the 7.3s. My experience was mostly diesel heavy equipment over the years and I've not been the primary on the 7.3s, but been involved with several, including this week.
It's mostly the same, but surely others will have 7.3 specific tips, differences, and gotchas.
Take a few minutes to shine a light into your turbo wheel, snap a few detailed pics if you can. Look for damage, wear, oil, etc. Only takes a few moments and it's cheap, LOL.
Matter of fact, take a lot of pics for reference before and during various stages of takedown. I reference my pics all the time. My recent IPR "adventure" was just this week. Read about them, never had to work on one before. Pics helped me look at condition while I was back home looking for one instock before going back to install it along the road
Take your time, keep it CLEAN, stay out of the way of moving parts, and you'll be fine.
Hope this helps!
OR
Now I remove the GP adapter, so 7 of 8 glow plugs are in and one cylinder has nothing in the glow plug hole and listen for any hole that sounds different than the others?
Lots of help. Thanks for taking the time to share.
You don't want any open holes while testing/listening. If there is air rushing out, puffs of air that you can feel, see, hear, whatever then that is not good.
If you have any of the GP holes open, of course air will come out of that hole while cranking, most likely drowning out anything else you might hear.
Have you replaced your GPs yet? OEM is the way to go. Reports of swelling and broken
tips preventing removal or falling into the cylinder with non-OEM.I bought mine at Advanced Auto for about $80 for a set. Can do a little better, but they had them the next am and I wasn't going to wait for shipping for a dollar or two each
Reason I ask- now would be a good time to remove the old one in a given cylinder, do your compression test, then install a new one in that cylinder and move to the next one. Might be less of a chance of a problem with an old or damaged GP.
Also be sure to look at each GP as you remove it. Make sure there isn't excessive carbon on it and no missing pieces. Go ahead and compare it to a new one, or remove two at once (one gets a new one until you test that cylinder, the other gets tested).
Next item....
Have you done a cylinder contribution test with AE yet? A buzz test?
We buzzed all 8 cylinders, sounded fine. Then did a CCT, #8 failed with a code. We then did a compression test of #8 (0 psi
) and #7 (around 300 or so psi) to confirm what AE told us and the isolate injector problem from a cylinder problem.We also performed a Cody test, but didn't hear any gurgling and it held pressure (injectors and orings aren't terrible and bypassing oil)
In our tested engine, there is a noticeable vibration, too. We pretty much "knew" the problem, but were working on a troubleshooting procedure to save diagnosis time, too.
Next item....
I also did PERDEL at the same time:
PERDEL:
Since I'm going to do the o-rings even if the test passes, is there any value to trying it beforehand?
One caveat - I've never tried a Cody test with fresh O-rings on dry sticks. I don't know if the lack of a warmup, retorque, and a full oil rail will taint the results in that situation.
I was thinking hearing gurgling to blame the injectors that could explain a lower compression result would be a "go" to do the orings, whereas a low compression and no gurgle might indicate a bigger problem that might need investigated before going any further- ie injector orings.
Make sense, or am I off base? Or maybe not that big of a deal in his case
I'm thinking that a Cody test could pass for marginal o-rings - 100 PSI might hold up fine, but ~3,000 PSI could leak - make sense?
I started with cylinder number 1, then moved to cylinder 3, 5, 7 and so on. Helps not to loose track of which one you already did. Shouldn't though as I hope you are writing these numbers down.
I started with cylinder one on a worm engine. Remove glow plug (I used a long set on needle nose pliers), clean glow plug hole with rag (if using air place rag over air nozzle and spray with air The rag will help from oil spray). Install compression tester hand tight only. Do not wrench it on there.
In your case, you can do what ExPaCamper said and disconnect the 42 pin connector. I hung mine up with a zip tie attached to the cowl and or pull number 30 fuse to disable the engine harness.
With compression test gauge hooked up and out of the way of moving parts, crank motor over 8-10 times to get a solid reading.
Remove compression test gauge. Install new glow plug and move onto next cylinder.
I also tried to do an engine running test, but my compression test was not having it. If you decide to do this you need the 42 pin connected and all glow plugs in except for the one your testing as you will have the gauge in that hole.
Here is the kit I used. Compression test from Star tools. Nothing fancy but worked.
