Here's a small update. I pulled the wiring harnesses out of the blue truck and the green truck to clean up the all the PO's hacks. Both harnesses had 45 years of dust and dirt on them so removed 5 lbs. of tape then half filled a 5 gal. bucket with one part Simple Green and 2 parts water and let them soak. After rinsing them off and letting them dry I put them in a desiccator to make sure every bit of moisture was removed from the harness.
I had to hack off the '70 instrument cluster connector, extend the wires and solder on the mating connector for the F600 cluster.
This is the new harness for the tail lights and trailer connector. I got it spliced together and installed in the truck.
I ran into a snag trying to swap out the old amp meter with a volt meter on the F600 clusters. The needle hub hits the bezel so I had to push the volt meter back. I needed to obround recess in the back panel to be round so the gauge will be pushed back away from the bezel.
I used a washer and piece of round stock to make the round recess in the back panel.
It fits! Now I just need some plastic shoulder washers or I'm going to see a lot of sparks.
Painted the hub black, I think it looks better than the white hub.
I'm thinking that Jeff-Row is right, its a shame to cover up those brackets. If you show your truck, you will have to mount a full length mirror under that bumper.. Most people have never seen anything like that. Other than Trozi's valve cover, not much is in that class..
Do you have a milling machine? That is a way clean design. Kudos again amigo..
Baja
Thanks! I have a little mill that I got back when I was machining a lot of prototype and pre-production parts.
Originally Posted by Randle
Nice looking work, as usual, love all the detail
Hi Randle, I hope you're feeling better buddy!
Originally Posted by f100today
WOW! That is bad a$$. Very nice work!
Thanks man! I wish my welds looked half as good as yours.
Originally Posted by EO2SeaBee
I think we are seeing the Mona Lisa being painted in copper and steel. Great stuff as always. The craftsmanship and attention to detail are amazing!
Wow! Thanks Doug! Thank you for your service and making the go juice for our trucks!
Originally Posted by 67nukeford
Those bumpers mounts are beast!! Nice job on the gauges, too!
Thanks Pat!
BTW, how does that desiccator work? I've never seen one.
It's a chamber you can hook to a vacuum pump to remove water but you can also use it with a chemical desiccant as a dryer. I just use a vacuum pump.
Originally Posted by Freightrain
Fantastic work. Like the dryer idea for the wiring. Looks like a brand new harness. Hopefully the insulation is not too dried out.
The insulation is in really good shape for it's age. I was surprised at just how flexible it is. Thanks for the complement.
Originally Posted by SavageNFS
You're just showing off now...
well done Gavin
Thanks bro!
Originally Posted by JEFFFAFA
Way COOL Gavin. I'm pretty much thinkin' it's a shame the bumper covers up the brackets and your work.
Thanks King Jeff! It was a royal PITA to keep a wet edge on all the bars and plates, so the gloss black paint doesn't look that great.
Way nice amigo
Baja
You got that right Baja, Trozi's valve cover is way cool!
He should have it chromed
This project is so far over budget already...
The paint didn't turn out that great but it was a beautiful evening, a slight breeze, low 80s and not much humidity.
