Looks like your going to be having being a contortionist this weekend. IIRC the wiper **** has a clip right behind the **** like your heater controls, check the plug in at the washer reservoir to see if you have power that motor is an easy fix. It works the way you think.
yup. I should unplug that and get a helper to read a meter or something. I can get the wipers to work but not sure bout pump. then the **** is so worn out it spins on the wiper shaft and is hard to get turned again to make them stop...
more research time! and another new tire time.. drivers front wont hold air now. yay used tires...
got fed up with old tires and not holding air. Put on a couple 15's that were in the shed. yeah they tiny but they work. lol low pro 15 in the front and 16's in the rear!
well a balmy +4 out this morning, 39F for yo'all americans lol. Grumpy started fine and the high idle kicked in and he warmed up nicely. Had a great drive to work today to. if he complained i just put the foot down and he listened lol!!
If you can see it, my cheap "scratch windshield" I got has the scratch at the right end of the passenger side wiper lol
And for Blue: does that work? this is on a manual steering manual brakes truck with 302 4 speed
Thank you for the pictures. Is the adjustment installed in front of or behind the triangular alt bracket? That's the part Im not sure about. Thanks again. Glad the drive went well for you.
