Dad's Engine
Old May 2, 2014 | 04:08 PM
  #916
Gary Lewis's Avatar
Gary Lewis
LOL! I think I might be happier with the same color of polka dots on each side. I like symmetry.
Seriously, what did you use to do that? Maybe I could do that in ...... a but more subtle colors?
Old May 2, 2014 | 04:18 PM
  #917
ctubutis's Avatar
ctubutis
A free version of Photoshop-like image manipulation tools.
GIMP - The GNU Image Manipulation Program
Old May 2, 2014 | 04:36 PM
  #918
Gary Lewis's Avatar
Gary Lewis
You are obviously experienced in the use of GIMP. I have now downloaded and started it - only to discover that there is a steep learning curve, something similar to that of Photoshop. So, I'm not sure that GIMP is an option for me to change the color of things. Looks like it'll be easier to actually blast them and quickly paint them.
So, back to the questions, please.
Old May 2, 2014 | 05:08 PM
  #919
ctubutis's Avatar
ctubutis
Ask google how to perform a specific task using Gimp, there are usually lots of simple answers given by people and sometimes even step-by-step tutorials.
Old May 3, 2014 | 01:56 AM
  #920
FoxFord33's Avatar
FoxFord33
Google is actually my new shop manual. I do have to weed out the polka-dots, but it does bring up some interesting ideas!
Old May 3, 2014 | 08:50 AM
  #921
Rogue_Wulff's Avatar
Rogue_Wulff
Google can bring plenty of answers. It's figuring out which of them are *correct* and *relevent* that can the issue......
Old May 3, 2014 | 12:53 PM
  #922
FoxFord33's Avatar
FoxFord33
Too true! In order to use Google effectively, one must already have a basic understanding.
Old May 3, 2014 | 12:58 PM
  #923
RL250's Avatar
RL250
Just a heads up regarding your thermostat housing. The 81's have a taller housing so that the upper radiator hose has clearance. I am not sure if your modified bracket has solved this issue. For a clean look with the stock one, use hex keyed plugs instead of the square protrusion style commonly found.
I tried the 81 bracket with the 70's thermostat housing, and I was quickly frustrated. I am thankful for the part you sent. It has no clearance issues.
Old May 3, 2014 | 01:40 PM
  #924
Gary Lewis's Avatar
Gary Lewis
Thanks, but the modified bracket would clear anything as it sits well below the top of the block.
If you want me to mod yours send it over.
Old May 3, 2014 | 03:03 PM
  #925
RL250's Avatar
RL250
I think I will. Do you have satin black powder coat?
Old May 3, 2014 | 03:31 PM
  #926
Gary Lewis's Avatar
Gary Lewis
Yep. See my post in your build thread.
Old May 3, 2014 | 09:46 PM
  #927
Gary Lewis's Avatar
Gary Lewis
Ok, the overwhelming choice is for the air cleaner base and snorkels to be black and the brackets to be natural or stamped steel. (My wife and I are in complete agreement.)
Toward that end I brazed the adapter on the other HO snorkel today and blasted both of them as well as the alternator bracket with aluminum oxide, as described in Dad's Air Cleaner. I have lots of bolts and other parts to blast as well over the next few days and then will start powder coating things.
Old May 3, 2014 | 09:55 PM
  #928
bruno2's Avatar
bruno2
Let me know if you are doing aluminum anytime soon. I need to blast and clear that timing cover.
Old May 3, 2014 | 10:05 PM
  #929
Gary Lewis's Avatar
Gary Lewis
It will be a bit before I tackle the aluminum. Will probably want to do the air cleaner lid, valve covers, alternator, thermostat housing, and power steering bracket in one go. So the timing cover would fit in nicely.
Old May 3, 2014 | 11:13 PM
  #930
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Have you ever thought of using nitroplate to coat things?
Nitroplate.com
