Sponsored by: Real Truck
Monte's 04 Build Thread
Old Dec 5, 2014 | 05:37 PM
  #691
xmontex4's Avatar
xmontex4
This thread is should have a disclamer
"All who read and/or parricipate in the conversations enclosed within this thread are responsible for thier own spending and cannot blame other members for encouraging the spending of their own resources"
Or something like that lol.
Damnit i read the 4 wheeler article and now I really want it lol.
Old Dec 6, 2014 | 02:21 AM
  #692
Bently_Coop's Avatar
Bently_Coop
Do you guys ever check out Carli suspension systems? Deaver springs, custom valved Bilsteins. All sorts of cool stuff. They specialize in heavy duty trucks.
Dodge Ram Suspension, Dodge Suspension and Ford Super Duty Suspension Systems - Carli Suspension, Inc
https://www.facebook.com/CarliSuspensionInc?sk=wall
Edit: If you check out a post on November 3rd they mention a 99-04 coil spring conversion.
Old Dec 8, 2014 | 07:36 AM
  #693
wizkid00104's Avatar
wizkid00104
Originally Posted by 02TB250
Now you've got me interested in the OME lift. Hrm... this is just terrible for my bank account, almost as bad as my RC trucks.
I gave up RC trucks when I got my driver's license. I still have them all, but they are expensive as hell. My nitro truck's shocks were more expensive than the set I put on my SD....
Old Dec 8, 2014 | 07:39 AM
  #694
wizkid00104
Agreed. I also want it.... I'm very curious if the ride quality is worth the money... Its awful pricey just to look good.
More truck ****!!!! Ahhhhhhhhhh
Old Dec 8, 2014 | 07:56 AM
  #695
xmontex4's Avatar
xmontex4
Definitely worth looking into IMO I've been reading up on it and looking into Carli's coil over systems i cant wait to see what they come out with for the 99-04 trucks! If its not a massive improvement then i wont even bat an eye at it because its so pricey lol.
Old Dec 8, 2014 | 08:12 AM
  #696
wizkid00104
I think the old man emu is the best for the $$$$.
With that being said, instead of the coil overs, you may be able to have a spring shop make you a custom set of leaves that are much softer than standard lift suspension. From what I gather, the trick to a nice riding leaf spring is to use several thin leaves instead of a few thick ones. And you want to paint the springs with the graphite based paint so that they slide over one another easily. I'd bet a spring shop could make a set of 4 for less than $2k which would put you in emu territory price wise. Then it is just a matter of finding a shock that is a good match to the springs.
Old Dec 8, 2014 | 12:05 PM
  #697
Spool&Go's Avatar
Spool&Go
Lol don't worry about derailing we all derail all the time until i post pictures.
Are you referring to the screws that hold the plastic liner to the fender lip? I had two which were 10mm and they were about 1/2" long i reused them for my flares. There may be 3 per side but i only had two one on the front and one in the top of the arch the lower side towards the cabd i just got some self tapping screws and used then to go through an existing hole in the fender that looked like it was for a screw because my dad put mud flaps on it when he owned it which used its own hardware.
Does this answer what your asking? Nice looking truck in the sig btw man!
Thanks for the info and the comment on my rig = ).
I used those two existing bolts on the front as well for the flares then used the self tappers.
Still need to do the rears.
Reps!
Old Dec 9, 2014 | 04:31 PM
  #698
xmontex4's Avatar
xmontex4
No worries man ask any questions thats what thw forums about!
Also removed the X brace today love my new sawzall lol pics to come!
Old Dec 9, 2014 | 05:22 PM
  #699
xmontex4's Avatar
xmontex4
Pictures as promised i apologize for the crappy quality i didn't have my work light set up so there wasn't enough light for my phone camera i will start taking pic with the fiances nice camera she got for her photo class
Before:
After i had my way with the new sawzall he he he
I tried to mock up the Ex skid plate but i need to get the ends out fof the fram first and notch the skidplate to clear the exhaust. My exhaust might get in the way though...you should all know what that means then
Also i am thinking about getting some new rear shock mounts that way i can POR behind them and also the Carli ones look a good bit stronger since they wrap around the top of the shock and it bolts through not into the side of the mount:
http://www.carlisuspension.com/ford-...ockmounts.html
Old Dec 9, 2014 | 07:06 PM
  #700
02TB250's Avatar
02TB250
Those mounts are for an 08. I'm not sure if the frame is the same or not. You may run into an issue with lengths of shocks
Old Dec 9, 2014 | 09:46 PM
  #701
xmontex4's Avatar
xmontex4
That was my first though to but if you read the instristions provided it says they become side specific for 05-07 which is the same as 99-04 correct? So going off that i was assuming instead of either bracker mounting to either side it should just be specified.
Old Dec 10, 2014 | 07:21 AM
  #702
wizkid00104
Those look really nice Matt. I am thinking with those Carli mounts, you will have to move your bottom shock mounts in on the axle inward. Those new ones are made to clear a 3" King shock so I bet they offset the shock from the frame rail. That being said, I wonder if they would interfere with Excursion tank. May be worth a phone call with Carli to check if they fit Excursion.
Old Dec 10, 2014 | 07:54 AM
  #703
xmontex4's Avatar
xmontex4
Never thought of that I'll try and contact them to see what they say. I know the tank skid plate needs to be notched though, the document i posted before never mentioned it but i noticed in a couple of the pictures towards the end of it that some of the plate had been cut off.
Old Dec 10, 2014 | 08:16 AM
  #704
wizkid00104
See, I can slow your spending as much as I can accelerate it
On an unrelated note, you may find this as interesting as I did: Mr. Cobra's Garage Is Worth A Pilgrimage For All Shelby Cobra Fans
Old Dec 10, 2014 | 11:26 AM
  #705
xmontex4's Avatar
xmontex4
That you can lol
