BIG RED's build thread
Old Jan 3, 2014 | 06:12 PM
  #1126
DIYMechanic's Avatar
DIYMechanic
Originally Posted by ReBilld
I can fix everybody's crap but mine! LOL!
Believe me, I know the feeling...
Old Jan 3, 2014 | 06:14 PM
  #1127
ReBilld's Avatar
ReBilld
At least we can fix something......right? LOL!
Old Jan 3, 2014 | 08:47 PM
  #1128
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
I read somewhere that was a wrong gasket (different model), that causes the leak, IDK, just in case, but Im sure you used the right one
Old Jan 3, 2014 | 08:51 PM
  #1129
strokin'_tatsch's Avatar
strokin'_tatsch
I assume he used the early build gasket and pump since it's a '95. Definitely a good question and it did need to be asked.
Old Jan 3, 2014 | 08:57 PM
  #1130
ReBilld's Avatar
ReBilld
Yeah, the new one I put on today was the early gasket, and the one I took off was too. Aaron suggested the check valve plug in the block between the HPOP and head on the driver side. He said it has an o-ring on it too. There is oil around that plug, so I'll check that tomorrow too.
Old Jan 3, 2014 | 09:04 PM
  #1131
strokin'_tatsch
There is an o-ring on it. Never seen it leak, but that's another good idea. Its a kind of a PITA little bugger to mess with. The HPOP is fed oil via that check valve during cranking and initial start up and prevents the HPOP rez from leaking down while sitting as well. With that in mind, I would spray carb cleaner down there and get it cleaned up. Then I would watch it during cranking/initial start up if possible.
Old Jan 3, 2014 | 09:48 PM
  #1132
ReBilld's Avatar
ReBilld
I can't see anything leaking while it idling, but if I take it for a short drive, there is a little puddle in that first low spot in the valley behind the HPOP, so it only leaks when the ICP is up.
Old Jan 3, 2014 | 09:55 PM
  #1133
martin72's Avatar
martin72
Hope you get this figured out Bill I hate problems like this.
Old Jan 3, 2014 | 09:57 PM
  #1134
ReBilld's Avatar
ReBilld
Thanks bud. I'll get it eventually.
Old Jan 3, 2014 | 10:23 PM
  #1135
fordpride's Avatar
fordpride
For chits and giggles check this
https://www.ford-trucks.com/forums/1...e-problem.html
Old Jan 3, 2014 | 10:41 PM
  #1136
ReBilld's Avatar
ReBilld
Originally Posted by fordpride
I can look under the pump with a mirror, and it is dry. It looks like the oil is coming from the HPOP gasket right at the bottom, but it's not. It is wet from there all the way over to where the fuel return line comes out of the driver side head. If I had a smaller mirror that I could get in there, I want to look at the bottom of the oil galley plug on the front of the driver side head. It's got to be that, or the front cover is leaking under the HPOP, or, the check valve plug that Aaron mentioned. I really don't think it's the front cover though. I'm gonna try to track it down tomorrow. I'm gonna clean and dry everything again as best as I possibly can, and then go from there. I might even try the flour trick if I have to.
Old Jan 3, 2014 | 10:47 PM
  #1137
fordpride's Avatar
fordpride
We don't need to know what you do in your bedroom
Old Jan 3, 2014 | 10:49 PM
  #1138
oldbird1965's Avatar
oldbird1965
Sorry Bill, I also hate leaks!!!!!!!
Old Jan 3, 2014 | 10:56 PM
  #1139
ReBilld's Avatar
ReBilld
LOL!! After seeing "the pics" of my wife......deep down you really wanna know....you know you do.....
Thanks Glenn. I'll find it if I have to tear the engine apart! I been working on it this long....what a little longer! LOL! Seriously though, I'm hoping to find it tomorrow. I really need to get it fixed so I can get my truck out of the shop. I have several other things to work on........I need a bigger shop
Old Jan 3, 2014 | 11:22 PM
  #1140
oldbird1965
I am been looking for a leak for a long time and I think I found it yesterday. The passenger side VC in the back somehow got a dent in it where it seals on the valve gasket. It was dented 'up' allowing the oil out. It would run down and drip on the exhaust manifold and burn off so I never saw a leak on the ground. I thought the motor was using a little oil. I straighten the dent the best I could but haven't tested it yet to see if that did the trick.
Also the auto fluid out line by the DP was leaking and the nut was rounded off. I got another out of the junk yard but a last effort used vice grips on it and it stopped leaking, for now LOL Good Luck!
