BIG RED's build thread
Old Dec 19, 2013 | 07:47 PM
  #1036
427 fordman's Avatar
427 fordman
That's gotta be about the size on mine too.
Old Dec 19, 2013 | 09:18 PM
  #1037
DIYMechanic's Avatar
DIYMechanic
Sorry to hear you're having trouble, Bill. You'll get it licked yet.
Old Dec 19, 2013 | 09:22 PM
  #1038
ReBilld's Avatar
ReBilld
The drain is definitely too small. It pushed some oil through the seals on the turbo. I'm gonna make the drain bigger and Travis said it may seal back up. If not I'll have to put new seals in the turbo.
Old Dec 19, 2013 | 09:25 PM
  #1039
DIYMechanic
Well, at least if you do have to reseal the turbo, it will be easier to pull off the truck than the stock turbo...
Old Dec 19, 2013 | 09:28 PM
  #1040
ReBilld's Avatar
ReBilld
LOL! Yep!
Old Dec 19, 2013 | 10:07 PM
  #1041
fordpride's Avatar
fordpride
Didn't I tell you not to break it
Old Dec 19, 2013 | 10:11 PM
  #1042
ReBilld's Avatar
ReBilld
LOL! You know I don't listen very well
Old Dec 19, 2013 | 10:29 PM
  #1043
strokin'_tatsch's Avatar
strokin'_tatsch
Hopefully it will stop blowing oil past the seals when you lower the pressure in the center section. The oil should be able to flow freely out of the drain, so pressure within the center section should be very low. Since you said it didn't blow enough to coat the compressor housing in oil, I'm hoping the seals are OK. We'll see soon I hope. Lol
Old Dec 20, 2013 | 01:22 AM
  #1044
stainlessstroker95's Avatar
stainlessstroker95
seems like after every build there is bugs that needs worked out.
Old Dec 20, 2013 | 06:35 AM
  #1045
El Camino Man's Avatar
El Camino Man
^^^ Agreed!
Old Dec 20, 2013 | 06:42 AM
  #1046
OldWoodsDiesel's Avatar
OldWoodsDiesel
as I'm trying to learn things about turbos here, I'm figuring you're talking about the two external tubes that go into the center section of your turbo, there, Bill? with the upper being the supply and lower being the drain?
if this is correct, shouldn't the holes be sized correctly from the manufacturer, or have you done some add-on/mod work to the turbo? or maybe LPOP?
sorry for the stupid questions if I'm way off-base here, but like I said, I'm trying to figure out the direction I want to go myself with my upcoming build.
Old Dec 20, 2013 | 07:25 AM
  #1047
fordman67's Avatar
fordman67
Yea.that's it.he did a diy built by bill kit..it is just getting sorted out no biggie.
Old Dec 20, 2013 | 05:29 PM
  #1048
ReBilld's Avatar
ReBilld
I'm gonna make a new piece for the bottom of the turbo and a new piece where the oil drains in the block and make them both to use 1/2" pipe instead of 3/8". I'm making the new drain pipe with 1/2" copper (5/8" O.D.)
Old Dec 20, 2013 | 06:48 PM
  #1049
strokin'_tatsch
You and that dang copper. Go get you some stainless tubing or braided stainless with AN fittings already! LOL!
Old Dec 20, 2013 | 07:18 PM
  #1050
stainlessstroker95
He has alot left over from making his moonshine stil haha.
