BIG RED's build thread
Old Jan 5, 2014 | 11:29 AM
  #1156
joshjen2000's Avatar
joshjen2000
Bill, Aaron and I would be glad to help if we can next weekend! I'm a professional flashlight or shop light director!!
Old Jan 5, 2014 | 11:59 AM
  #1157
OldWoodsDiesel's Avatar
OldWoodsDiesel
Man, bill - if it wasn't for bad luck...
I'm sure you though of this, but might it save some time to just yank the radiator and pull off the grill. When disassembling my red truck, there was pretty easy access to the fan/WP with those two out of the way.
Just a thought.
Good luck!
Old Jan 5, 2014 | 01:57 PM
  #1158
strokin'_tatsch's Avatar
strokin'_tatsch
Just a thought.
Good luck!
In order to pull the front cover off, the oil pan has to be removed. The only way to do that is to pick the engine up and get it away from the crossmember.
Hate to hear that Bill. I'm sure you'll get it done tho and while the pan is out, it'll be a good time to replace the dipstick o-ring correctly or correct that whole problem from ever happening.
Old Jan 5, 2014 | 02:31 PM
  #1159
fordpride's Avatar
fordpride
I wouldn't just lift the engine. Doing that you take a chance of driping down and contaminating the sealer before it dries.
The correct way to seal the pan is to have the engine turned over.
Old Jan 5, 2014 | 05:38 PM
  #1160
DIYMechanic's Avatar
DIYMechanic
That really sucks Bill. Sorry to hear you're having all that trouble. Let me know of there is anything I can do to help. I'm not that far away.
Old Jan 5, 2014 | 07:12 PM
  #1161
tshrager's Avatar
tshrager
Pick me up on the way!
Old Jan 5, 2014 | 07:30 PM
  #1162
fordman67's Avatar
fordman67
Were going to visit the pimp friday night :-)
Old Jan 5, 2014 | 08:18 PM
  #1163
tshrager's Avatar
tshrager
That's what I hear. I told him I woulda tagged along! Lol
Old Jan 5, 2014 | 09:27 PM
  #1164
martin72's Avatar
martin72
Sorry to here your going to have to pull the motor Bill that sucks. What would cause the front cover to start leaking or do you think it was leaking before.
Old Jan 5, 2014 | 09:33 PM
  #1165
ReBilld's Avatar
ReBilld
Originally Posted by BBslider001
Good Lord Bill, you just made me real tired!! LOL
It makes me tired thinking about it Byron! LOL!
Originally Posted by 427 fordman
Well, that sucks big time bud. I hear ya on the way too much to do, that's sure not what you needed right now with your list!
I know you know this, but check out your oil pan real good means the motors coming out.
I will bud, Thanks!
Originally Posted by El Camino Man
Holy cow... If I put all that work into a truck, had to pull the tranny and put it back THEN realize the engine needs pulled...Id scream!!!
It's not that bad JP. Just a little more work is all
How do you correct it from ever happening? You're talking about that $300 aluminum piece are you?
I appreciate that Nate! I'll be fine though. The only bad part about pulling these engines removing the core support. I may start on it tomorrow evening. I got one of the engine stands freed up today so I have one to put it on. Shouldn't be too bad.
Old Jan 5, 2014 | 09:47 PM
  #1166
oldbird1965's Avatar
oldbird1965
Well, your optimistic anyway. I'm sure your positive you have to or you wouldn't. Good Luck!!
Old Jan 5, 2014 | 09:55 PM
  #1167
ReBilld's Avatar
ReBilld
LOL!! I tried every way in the world to convince myself that it wasn't the front cover leaking.....but it is. I never dreamed it would be that, but after cleaning with brake cleaner and getting it to start leaking, with an inspection mirror and a flashlight, standing on my head looking under the HPOP, I could see where it was coming from. It is leaking directly above the oil passage hole from the front cover to the block.
Old Jan 5, 2014 | 10:49 PM
  #1168
RoughinIt's Avatar
RoughinIt
Well quit talking about it and do it already... We got to get my truck in there and get it built!
Old Jan 6, 2014 | 12:52 AM
  #1169
strokin'_tatsch
That or I believe swamps uses a billet steel nut and tig welds it to the oil pan on all the engines they build. I think that would be a more permanent fix. Either see if someone can machine that nut out of steel or call swamps and see if you can buy one.
Old Jan 6, 2014 | 06:13 AM
  #1170
fordman67's Avatar
fordman67
Uh oh....i know who that is lol...now we are all in big trouble!!
