110 is the stock alternator, 140 is an upgraded one. You can either ask for the stock 140 (its not an upper of the dual, its available as the 63H upgrade). If you do a big case 3G to 6G, you need this harness that plugs to the new 3G with two plugs, and plugs into teh stock connector on the alternator which was for a 6G. This pigtail is part# W2740 apparently. Anyone have the part number for the alt in a 3 G 140 amp with the smaller 57 or 58 mm pulley, with 8 grooves?
I ordered a 135 amp alt for a 97 powerstroke, and then ordered the small pulley and adaptor harness off ebay. The links for the pulley and harness were posted earlier in this thread. I have been super happy with this upgrade, puts out great at idle! Many thanks again to all the smart guys on this forum, especially Josh!!
Yahiko, what I am saying is the 140 is available as a upgraded single alt, not only the upper of the double set up.n there are many of us up here in Canada with upgraded alts because they will never cope in the winter without one. I am looking into this 3G bad boy. That would be really slick, as I can't wait much longer as my alt is the original 8 years old, 8 winters.
Well.
All I can say is Grrrrr. 2 cells on the old battery that O'Reilly would
not replace are a bit lower on the specific gravity tester than the
other 4. It's the center 2 that are the low ones also.
I did try something that I would not normally do and that was to do a
normalizing charge. In other words a controlled over charge. Flooded
cell battery is 15.5 Volts till SG stops changing. It took about 3 hours
to reach that point. I was not happy with the results. I'll have to wait till
the next start to see if it did any good. If not it's a full set of new batteries.
Sean
Well some good news today. I guess my home O'Reilly's store is going to
change. The manager replaced the 2nd battery. This is the same store
that replaced the first bad one. They are not so close to me but will
now be my go to store.
It was nice to see 11.7 after a start and not the quick flash of the 10.9
I have been getting.
I will put the charger on the one older battery and charge it and then do
the new one so they start at a full charge and see how that does.
Has any one looked at this alt? Napa part number 1n3108ho. 200 amp 3G ford
I like that its Lifetime warranty and 200a, but @ $370 and no pulley (which I would probably add a 58mm anyway) and you must use Cable Kit 13-31K ...kinda up there $$.
I ordered one. And they offered it for 285, before military discount. I am not going to be arable to pick up for a couple of weeks due to going out of town. The pigtail I ordered showed up today
Nice! Looking forward to hearing what voltage you see during cold start.
If I had to guess I would expect to see around 12.8-13.0 volts at the OBD port after start.
Now I'm wondering if shoulda, woulda, coulda went bigger!
Guess, I'll find out.
ScanGauge says 11.8 at start, then runs 13.7 / 13.8 .....
Chris
Was your alternator from NAPA, I just recently purchased a reman with a lifetime warranty with 135 amp, took back days later to exchanged for another.. Was a bad alternator, my battery light was coming on and I have 2 brand new Duralast 850's. Replaced with the new one and I have not had an issue, only day 2 though.
My wifes 05 is getting an alternator soon so i have been reading this post, i did some looking around at the NAPA site and found this, kinda interesting!
Read it carefully!
