Alternator taking a crap, time to replace!
Old Nov 1, 2013 | 10:20 AM
  #241
MisterCMK's Avatar
MisterCMK
Originally Posted by npccpartsman
You got that right. I wish I'd have done that YEARS ago instead of a couple of months.
Originally Posted by Bullitt390
So you guys completely removed the deflector and stator?
Got any pics for curiosity sake of that looks like?
Our F550 pump trucks at work do not have the stators installed since there are belt driven PTO pumps etc mounted up front.
Josh
See the pic at the bottom of my post.
Originally Posted by POORBOY1964
Mine will go away the next time I do anything under the hood.
I'll try to get some pic's. When the stator goes the deflector goes with it. I couldn't tell any difference in cooling. Lots of folks on the .Org have done it. Sure makes it nice to swap anything on the front of the motor and no special tool required to get to the belt tensioner.
dlibson is the guy I have to thank for it. When we swapped my transmission we pulled the stator and it has been sitting on a shelf since then.
Originally Posted by LivingLarge
Same here, I see 13.6 on OEM with A/C on. Time for a DC Power
Check your voltage at the battery. The OBDII port is going to read lower than the actual charging voltage.
Old Nov 1, 2013 | 10:23 AM
  #242
AlaskanF350's Avatar
AlaskanF350
so when my scangauge says its charging at "14.0 Volts" it is higher?
new alternator earlier this year.
Chris
Old Nov 1, 2013 | 10:27 AM
  #243
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Chris
I notice about .2-.4 volts more at the battery versus OBD port.
Josh
Old Nov 1, 2013 | 10:29 AM
  #244
Bullitt390's Avatar
Bullitt390
Wow, that does add a lot more space up front.
Thank
Josh
Old Nov 1, 2013 | 10:48 AM
  #245
AlaskanF350
I am not an electrician, but I believe even .4 over 14 isn't going to harm anything
I hope
Chris
Old Nov 1, 2013 | 10:57 AM
  #246
Bullitt390's Avatar
Bullitt390
I hope
Chris
14.4-14.6 is perfect.
Josh
Old Nov 1, 2013 | 11:11 AM
  #247
AlaskanF350
Bullett,
Thanks,
Chris
Old Sep 7, 2014 | 05:13 AM
  #248
Yahiko's Avatar
Yahiko
Bump.
Fall is almost here and winter well be right after.
Well they tell me that is. But you never know sometimes
a warm winter will catch you.
Time to give the batteries some thought.
Sean
Old Sep 7, 2014 | 08:25 AM
  #249
the_auto_tech's Avatar
the_auto_tech
I get new ones every 2 years from Wal-Mart for free.
Old Apr 10, 2015 | 10:00 AM
  #250
xaviar's Avatar
xaviar
Just ordered my pigtail conversion off eBay and adding a bump to a great thread.
Here's the link to eBay
http://www.ebay.com/itm/Alternator-C...2627b9&vxp=mtr
Old Jul 16, 2015 | 11:48 PM
  #251
Yahiko's Avatar
Yahiko
But to the top for the guys having alt problems.
Lots of good info here in at long lasting thread.
Sean
6.0L Tech Folder
Old May 2, 2016 | 06:03 PM
  #252
2wdDezlX's Avatar
2wdDezlX
Thought I would bump this up and share that I got my pigtail from same eBay ad today.
Now just need to find the best deal on a 3G!
Old May 3, 2016 | 03:10 AM
  #253
WatsonR's Avatar
WatsonR
Get the Prestolite Neece-Leville 230amp alt... best deal in amperage output.
If that's not in the price picture, get the 2005 upper alt at 140Amps, use TRT30 for Advance Auto on-line coupon code, do in store pick-up and save $50 with that code.
Neither of these listed need the pigtail. I carry mine as a just in case while on the road and can only get a 3G alternator. Buy from Advance and really not worry.
Old May 3, 2016 | 09:28 AM
  #254
2wdDezlX's Avatar
2wdDezlX
Well, currently I have the crapp 110 and it's on its way out. I looked at the 140 upper alt but they are a little more money and not as common as the 3G. So, I think I'm going to get the 3g from advance. I already had it in my cart with the promo code and I had $10 speedperks. I love the Trt30 code.
Then, if this one goes out I can get either the large 6g or 3g no matter where I'm at.
Old May 3, 2016 | 09:41 AM
  #255
WatsonR's Avatar
WatsonR
Exactly... I use the crap out of that code! Don't let the cart get above $150, that saves you $50 off each time.... just check out a bunch of times and keep hitting the code.
