Alternator taking a crap, time to replace!
Old Oct 28, 2013 | 04:48 AM
  #211
npccpartsman's Avatar
npccpartsman
Originally Posted by jdw1
My wifes 05 is getting an alternator soon so i have been reading this post, i did some looking around at the NAPA site and found this, kinda interesting!
Read it carefully!
http://s7d9.scene7.com/is/content/GenuinePartsCompany/686615pdf?$PDF$
Yeah.......pretty much kills a good warranty for our trucks, huh?
Old Oct 28, 2013 | 05:46 AM
  #212
jdw1's Avatar
jdw1
Seems like it kills a good warrenty for anything!
How can they put a lifetime warrenty on a part for your truck and then say "if it's on the truck you bought it for its only good for 2 years", sounds like a scam to me!
I looked at Autozone and Advanced Auto's warrenty too, doesn't seem real clear eather! IMO, buyer be aware.
Rant over.
Old Oct 28, 2013 | 06:51 AM
  #213
Monty Simmons's Avatar
Monty Simmons
Reading that warranty, if the GVW is over 8000lbs, there is no warranty that I can see.
Further, the "lifetime warranty" is for defects in "workmanship and materials."
The warranty specifically excludes failure due to "wear".
Not much of a lifetime warranty when one "reads the fine print".
LIMITED LIFETIME WARRANTY
Your NAPA NEW Alternator and/or Starter are warranted by BBB Industries to be free of defects in workmanship and materials. This limited lifetime warranty is not transferable.
The Warranty DOES NOT cover: (1) any losses due to misuse, accident, abuse, neglect, wear, or improper application or (2) products that have been altered.
Replacement Guidelines:
1. Purchase product through a NAPA NEW Installer or NAPA Auto Parts Store.
2. Save the original receipt.
3. Should you need to replace this product, return the defective parts, along with a copy of the original receipt, to your original NAPA NEW Installer or any participating NAPA Auto Parts Store.
This warranty applies to American and import cars, vans and light trucks under 8,000 lbs. G.V.W.
Old Oct 28, 2013 | 07:37 AM
  #214
the_auto_tech's Avatar
the_auto_tech
Sometimes it just depends on who you're dealing with too. Most of the parts stores around here will do good business with me to keep good business with our dealership.
Old Oct 28, 2013 | 08:39 AM
  #215
69cj's Avatar
69cj
I've never had AutoZone refuse me on a lifetime warranty and you don't need the receipt. You're in their computer.
Old Oct 28, 2013 | 09:32 AM
  #216
99ExpyProblems's Avatar
99ExpyProblems
Ditto for Advance Auto.
Old Oct 28, 2013 | 09:53 AM
  #217
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I can say the same for both as well....
The only problem with Advance Auto is that their computers are not all tied together and you have to go to the specific store you bought the part from or it to be warrantied. Autozone and O'reilly don't have that problem and I haven't had either tell me they couldn't warranty something that failed.
Even so, I'll just take the cheaper method and see if a local shop can rebuild it, better, and cheaper when/if the alternator fails on the '05.
Old Oct 28, 2013 | 10:13 AM
  #218
99ExpyProblems
With Advance, I have been in Georgia and Florida and swapped an alternator after they called the store in South Carolina and verified the warranty.
Old Oct 28, 2013 | 10:30 AM
  #219
69cj's Avatar
69cj
The only problem with that is you'd better be close to home when it fails.
Old Oct 28, 2013 | 11:55 AM
  #220
Toreador_Diesel
Hmmm....
Toucher....
Old Oct 28, 2013 | 05:38 PM
  #221
billtrev's Avatar
billtrev
Originally Posted by Texas Bob
Now to the point. If I needed to replace/upgrade my alternator today, I would consider a new Bosch AL7606N (with no core requirement) offered on Amazon for $151 plus state sales tax but no shipping cost. I've only owned one Bosch alternator which was on a '68 VW Fastback and it outlasted the car. Since the my truck is used mostly for towing on the road, I would stash the existing alternator 110 in the trailer for an emergency. And if I got eight years out of the Bosch, I would be satisfied.
Any thoughts on this approach?
I hope this approach is a good one since that is exactly what I did.
Installed the Bosch AL7606N yesterday as preventative maintenance. Original alternator was still serviceable but after eight years and almost 100,000 miles I figure I got my moneys worth from it. Plan on rebuilding the original OEM one and keeping it as a spare. We'll see how the Bosch unit holds up...
Old Oct 29, 2013 | 10:27 PM
  #222
jdw1's Avatar
jdw1
Well i ended up ordering one of these today,
6G Series Ford 7.3L, 6.0L, 6.4L, 6.7L Power Stroke Diesel Heavy Duty 140 Amp Alternator Upgrade
mainly because of the HD bridge rectifier, i talked to Randy at Quick Start about the 3g and according to him the 6g large case is better because it has a larger bearing in the back and bigger fan's and the case is more open for better cooling. I have been running one of these on my 02 for about 3 years now (from Quick Start) with good results, i plow snow with the truck in the winter and one thing i have noticed is that i can stop and pop the hood and feel the alternator and it is always running cool while plowing snow.
We will see how it does under the hood of a stock 6.0 with no extra power demands!
Old Oct 30, 2013 | 08:13 PM
  #223
Texas Bob's Avatar
Texas Bob
Billtrev,
How was the install? Did everything line up? Was the electrical connection compatible with the OEM plug? Any negatives we should know about?
I'd be interested in knowing volts at idle and at 40 MPH+. Tonight I was waiting at idle for my wife to come out of the local Walmart and the volts were hovering around 12 or so. A tad low I'd say for a healthy electrical system.
Has anyone else installed the Bosch AL7606N and how did it go?I see you are running a 2005. Would the setup on an early 2003 be any different?
Thanks for your thoughts.
Old Oct 30, 2013 | 09:15 PM
  #224
billtrev's Avatar
billtrev
Billtrev,
The hardest part of the install was removing the air deflector (upper shroud) and locking the belt tensioner "kickstand", both of which will be much easier after having done it once. (I also replaced the belt while I was there.)
The alternator bolted right up. The electrical connections were in a slightly
different spot(the rear cover was "timed" 1/3 turn from where my OEM one was) but connected easily. The post connection is also pointed "up" on the Bosch unit a opposed to toward the back on the OEM but again no issue that I can see.
Going from memory the voltage at idle was right around 14 volts. The OEM was around 13.1.
I will have to check the voltage a 40MPH+ and get back to you..
I don't know if there is any difference with an '03. I would think they would be similar but I have no experience with them...
Old Oct 30, 2013 | 09:31 PM
  #225
Toreador_Diesel
And that confirms that my '05 is still running the OEM alternator.
I've been staring at it on my AE wondering why oh why it never goes to 14 volts like my 7.3 does.
Now I know why
