If I needed to replace/upgrade my alternator today, I would consider a new Bosch AL7606N (with no core requirement) offered on Amazon for $151 plus state sales tax but no shipping cost. I've only owned one Bosch alternator which was on a '68 VW Fastback and it outlasted the car. Since the my truck is used mostly for towing on the road, I would stash the existing alternator 110 in the trailer for an emergency. And if I got eight years out of the Bosch, I would be satisfied.
Any thoughts on this approach?
I hope that's a good approach since it's the one I just took. My alternator is taking a dump, it would seem. It will occasionally hit 13.0 or so on my SGII, when 13.8-14.0 used to be the norm. I ordered the Bosch last night and will stash the old one away in the trailer just in case since it should still be good enough to finish the journey. Wish me luck...
Well Good Luck!! I went back and looked at it again and the case and everything else I can compare looks exactly like my factory upgrade 140A unit. You gonna' try the overdrive pulley as well? I may try doing mine tomorrow, I'm battling a dribble from the newly installed coolant filter
You know it would not be that hard to plumb some cooling air into places in the engine
compartment both the FICK and Alternator could use cool air. Maybe a fan even.
Sean
I think those RAM Air Hoods would Push LOTS of Air threw there
But that style hood takes some getting used to for me
I might try the pulley, but I'm going to see how it does without it first.
Well after installing the NEW Alternator (Chinese)from the tag
I was getting good numbers after I started. Now I am not seeing the
good numbers as fast. So last night after it had been out for a good
drive I let it cool off for a few hours and dug out my battery tester.
I un-hooked the pair and took some readings 10 or above it a good
reading on this tester. My driver side battery was replaced back in
March under warrantee and it was reading a 10.2 and the passenger side
that they would not replace is reading 10.0 and when you read it a second
time it drops to 9.9 You can watch it drop during the reading unlink the
driver side that stabilized at 10.2 so.
How to deal with O'Reilly auto parts on this. If I drive in it will be hot
and charged up.
Note of FICM cooing. If you put a scoop somewhere on the grill that did
not block any airflow to other places that need it and use SCAT tubing
that is used in aviation to carry it to the FICM that would cool it during
forward movement.
and charged up.
What do you mean 10.2, 10.0 and 9.9? During cranking?
Engine off and after several minutes of rest the batteries should be 12.6 volts.
A battery is usually considered dead @ 12 volts even. It really depends on the strength of the acid and integrity of plates whether or not it can be charged and brought back to life.
and charged up.
forward movement.
Why not just measure battery voltage? Oreilly's has a load tester to load test each battery, have no idea what a "10" means on your tester.
Careful ducting air to the ficm, you might also duct rain water too...
When I took my truck to autozone I took an 8mm ratchet with me. Disconnected one lead on the driver battery and had them load test both batterys. One tested good one bad. They replaced both under warranty and even changed them out for me on the spot. Talk about service.
THe tool that was used does not use 12VDC like most would think.
It it uses a scale that is adjusted by what the CCA rheostat sets it too.
Any reading over 10.0 and you good for the selected CCA and any less
and it's weak the lower the number the weaker it is.
Anyway If I take the truck into a store it's been run so that is why I check at home.
Once it's been run the battery shows good/ok for a few hours.
I did stop on my way back from Seattle today and because they can't find my
paperwork for the batteries it more of a hassle to get them replaced. Most likely
I will just get a new set at Costco and keep the one that is the new one and find
a core for the it and let them have they pair that way. Costco have something
like $24 for a core fee on the silly things or was that Ford. I do know it seemed high.
Yes it does. It will read current and AC ripple. You get that when a diode is going.
I was going to do a Hydrometer test in the AM. The problem is the part store
wanting to do there own test. After running it........... You get the idea.
