1986 F-250 Progress Thread
Old Feb 25, 2015 | 08:17 PM
  #721
FordFETruck's Avatar
FordFETruck
Originally Posted by Gary Lewis
Ok. Thanks.
Are you considering using an electric fan once you get the truck back together?
Old Feb 25, 2015 | 08:19 PM
  #722
Gary Lewis's Avatar
Gary Lewis
I am considering it, but I'll want to use Ford fans if I do as that'll fit with the theme.
Old Feb 27, 2015 | 08:55 AM
  #723
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
See my comment in Matthew's thread Gary.
Old Feb 27, 2015 | 10:54 AM
  #724
Gary Lewis's Avatar
Gary Lewis
Saw it and responded with another question. But, I can research it myself. Thanks.
Old Mar 5, 2015 | 01:49 PM
  #725
FordFETruck
Alright, time to put my cooking pan fan shroud pictures here too.
Moves A LOT of air!
Fan controller override switch.
Old Mar 5, 2015 | 06:29 PM
  #726
85lebaront2
Boy that looks like my brake controller.
Matthew, it does look like a nice fan shroud!
Old Mar 5, 2015 | 06:36 PM
  #727
FordFETruck
It would look even better if I polished it. It is aluminum after all!
As far as the brake controller, I assume it's factory?
Old Mar 5, 2015 | 07:10 PM
  #728
85lebaront2
No, it is a Kelsey-Hayes I bought years ago from Hitch Headquarters in Hampton VA. Bought it not long after I bought Darth. He had an electronic one that was horrible, it would surge and pulse when you applied the brakes.
Old Mar 5, 2015 | 08:16 PM
  #729
FordFETruck
Our van has the same branded controller, but a different model. I highly doubt I'll ever even use the one in the truck. But, it's there.
Old Mar 5, 2015 | 08:52 PM
  #730
85lebaront2
If you ever want to part with it let me know, everyone has discontinued making them as you can't use them on ABS systems.
Old Mar 5, 2015 | 09:57 PM
  #731
FordFETruck
I will. The light lights up when I step on the brake, and the lever moves with brake pressure. So, I assume it works.
Old Mar 6, 2015 | 08:45 AM
  #732
85lebaront2
That's a pretty good check on it. Matthew, post #72 on page 5 of my rework thread has a good set of pictures of mine.
Old Mar 6, 2015 | 01:22 PM
  #733
FordFETruck
Yeah, looks like the same one to me!
Old Mar 6, 2015 | 05:21 PM
  #734
FordFETruck
Took the truck for a good drive today to a couple stores and back home on the freeway. Fan shroud works very good. Cools it right down and keeps it around 190 when idling after it runs for a minute. I floored it a couple times on the freeway and the holy crap o meter went high. That mechanical fan had a big drag on that engine before. No cooling problems at high speeds either. Runs at 190-195 on the freeway with the fan off. However, it was pinging at WOT. I have a brown secondary spring in, I'll go down to the next fastest opening spring rate. Should fix that. I know it's not the timing, it's 11* BTDC and full in by 3000 RPM.
Old Mar 11, 2015 | 07:44 AM
  #735
H311RA151N's Avatar
H311RA151N
Pretty clean truck you got there! I have to say your cooking pan idea turned out really nice and I'll bet it's surprisingly effective as well.
