1986 F-250 Progress Thread
Old Oct 13, 2015 | 10:46 AM
  #841
ctubutis's Avatar
ctubutis
Congratulations, Matthew! They made an Article about you, which is now (EDIT: was) on the front page.
Old Oct 13, 2015 | 02:24 PM
  #842
FordFETruck's Avatar
FordFETruck
Thanks! I didn't even see that yesterday.
Old Oct 13, 2015 | 03:14 PM
  #843
Gary Lewis's Avatar
Gary Lewis
Yep, Congrat's!
Old Oct 13, 2015 | 06:10 PM
  #844
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Congratulations!
Old Oct 13, 2015 | 06:27 PM
  #845
4x484150's Avatar
4x484150
Congrats! You've earned it with all of the work you've done
Old Oct 13, 2015 | 06:32 PM
  #846
FordFETruck
Thanks! all the work has paid off. Everything else breaks down, this one doesn't.
Old Oct 28, 2015 | 05:01 PM
  #847
FordFETruck
Alright, done some more stuff to it lately. I upgraded my Sunpro gauge lights to green LED's as well as the headlight/wiper light. Looks a lot better now they match the dash bulbs color. Changed the rear leaf spring bushings. That was a lot of work. I bet I got off the floor 80 times doing that job. Took about 10 hours in total, 9 yesterday and an hour getting set up the night before. Made a surprising difference in how it rides - much better.
I'm still sporting the old shackle bushings, as I couldn't get those out but those were in OK shape. The spring eye bushings were toast.
Old Oct 29, 2015 | 06:13 AM
  #848
GruesomeJeans's Avatar
GruesomeJeans
Nice work! I'll be going down the same path in the future when I do my suspension lift. It'll be tough. But first, axle work since I went and broke stuff, then a motor rebuild!
Old Oct 29, 2015 | 12:21 PM
  #849
FordFETruck
Thanks! those bushings are some real FUN! not. What did you break?
Old Oct 30, 2015 | 11:27 PM
  #850
GruesomeJeans
You already saw it but for those here that didn't, it was the pinion yoke.
Old Oct 31, 2015 | 07:30 AM
  #851
85lebaront2
You do good work. If you are careful you can change it without taking the whole thing apart. Since it is a 9" unit, check what ratio it is. If it is what Ford calls a "hunting" ratio then there is no worry about matching the gears unless you have to replace the pinion bearings.
Old Oct 31, 2015 | 03:28 PM
  #852
GruesomeJeans
I don't do quite as good as Matt .
I have 4.11s with Yukon Tru-Trac both front and back. A very recent upgrade. It just so happens that the yoke wasn't as strong as it could have been. However this one Mark Williams Enterprises - Detail
Should serve me just fine. I've been informed that this one, being made of Billet Steel, will shatter instead of bend and rip apart. At a price of $170+ I would hope it is correct. On top of everything I've been real nervous about the whole deal. Worried I damaged other parts inside, worried owning order the right part, and worried I'll screw up the reassembly and be in a deeper pit.
My chosen method of changing this doesn't require changing the crush sleeve or even resetting the pre-load. Just as long as everything matches up to exactly how it was before, aside from the torn up yoke of course. I guess we will see.
Old Oct 31, 2015 | 03:35 PM
  #853
FordFETruck
If you're not going to reset the pre load, paint a mark all across the nut, threads and the yoke for reference. CAREFULLY count the turns taking it off, then put it back on exactly the amount of turns you took it off.
Old Oct 31, 2015 | 03:36 PM
  #854
FordFETruck
Changed my cowl seal today. The old one was crystallized, no wonder it didn't seal worth a hoot.
Old Nov 1, 2015 | 02:41 AM
  #855
GruesomeJeans
Yup, that's the plan . I'm just going to take it slow and try to be very particular about things. Write down all the details and what not. One thing I'm wondering is, how much torque will I have to apply on reassembly. I haven't seen anything yet on the forums I had been reading about. They simply said "torque the nut back down then check the drag..." I've got my torque wrench, I just need to order the yoke, pull my drive shaft and get it in the garage to work on it.
Someone had also mentioned that I'm probably going overkill on the yoke I chose. It is kind of expensive but I am also looking at stroking my 351m at a later date so it would give me some peace of mind..
