Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Jul 25, 2016 | 04:05 PM
  #106
Hoke's Avatar
Hoke
There is a lot of valuable info on this sight! I would like some help with my VIN as well.F60D8410929 WB 156, color G, Model 602, Body 81B, GVW 19,500, HP 153, RPM 3600, DSO 34
I believe it is a 63, I see it is a F600. Not sure if it's a 292 or a 330. I'm trying to find ignition timing specs, but not sure which engine I have.
Any and all help would be appreciated.
Thanks,
Hoke
Old Jul 25, 2016 | 04:14 PM
  #107
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Hoke
There is a lot of valuable info on this site! I would like some help with my VIN as well.
F60D8410929 / WB: 156 / COLOR: G / MODEL: F602 / BODY: 81B / TRANS: / AXLE: / GVW: 19500 / CERT NET HP: 153 / RPM 3600 / DSO 34
Welcome to FTE
The 5th digit of the VIN is a letter, not a number. You omitted the TRANS & AXLE codes.
F60 = F600.
D = 292 4V Heavy Duty.
8 = This should be a letter for the assembly plant.
410929 = 1963, assembled May 1963.
156" Wheelbase.
G = Chrome Yellow.
F602 = F600 .. 19,500 lbs. GVWR
81B Custom Cab.
TRANS code = Omitted.
AXLE code = Omitted.
19,500 lbs. Gross Vehicle Weight Rating.
153 net HP @ 3,600 RPM
34 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 29, 2016 | 09:55 PM
  #108
Greenrivercummins's Avatar
Greenrivercummins
Howdy all was hoping y'all could Decode my Vin and tag please just picked it up last week. Here's the Vin tag.
Old Jul 29, 2016 | 10:14 PM
  #109
NumberDummy
Welcome to FTE
N75 = LN750 (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
C61829 = 1976.
184" Wheelbase.
T = Candyapple Red (there should only be one T).
LN752 = LN750 (gas), 23,000 lbs. GVWR
HC8: HC = Dark Tobacco Vinyl / 8 = Custom Cab w/o Butterfly Hood.
M = Clark model 285V 5 Speed Direct.
E2M:
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
M = This sorta looks like an M (but it might be something else) = Ford 7,000 Capacity Front Axle with Power Steering.
23,000 lbs. Gross Vehicle Weight Rating.
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 29, 2016 | 10:57 PM
  #110
Greenrivercummins
Thanks NumberDummy many thanks!!
Old Dec 7, 2016 | 06:12 PM
  #111
beartrace's Avatar
beartrace
Trailering
This is unusual vin: N80CVFF4033. What is engine size?
Thanks
Old Dec 8, 2016 | 05:41 PM
  #112
NumberDummy
Originally Posted by beartrace
This is unusual VIN: N80CVFF4033
What's unusual about it?
N80 = LN800 (gas).
C = 429 4V
FF4033 = 1979.
Old Feb 15, 2017 | 12:20 PM
  #113
zergio00's Avatar
zergio00
Could you please help me identify this truck?
Old Feb 15, 2017 | 12:40 PM
  #114
NumberDummy
R70 = LN700 Diesel.
O = Detroit model 6V-92TTA 552 cid 6 Cylinder Diesel.
DC6569 = 1979.
148" Wheelbase.
M = Wimbledon White.
R707 = LN700 Diesel .. 27,500 lbs. GVWR
8A8: 8A = Black Heavy Duty Vinyl-Full Width Seat / 8 = 81B Custom Cab w/o Butterfly Hood.
JC: J = CA emissions / C = Fuller model RT-610 10 Speed Direct.
AXLE code impossible to read, partially covered up by rivet.
27,500 lbs. Gross Vehicle Weight Rating.
711843:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
1843 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
Old Feb 16, 2017 | 12:10 PM
  #115
zergio00's Avatar
zergio00
Thanks!
Thank you!!!
R70 = LN700 Diesel.
DC6569 = 1979.
148" Wheelbase.
711843:
Old Mar 8, 2017 | 12:35 PM
  #116
bradlee hanks's Avatar
bradlee hanks
I have what I believe is a 1976 Ford F700 but I'm having trouble decoding the VIN *F77FVA62393* any information would be very much appreciated
Old Mar 8, 2017 | 10:36 PM
  #117
NumberDummy
Originally Posted by bradlee hanks
I have what I believe is a 1976 Ford F700 but I'm having trouble decoding the VIN *F77 FVA62393* any information would be very much appreciated
F77 = There's no such thing as a VIN series code (1st 3 digits) of F77.
F = 391 4V FT engine.
A62393 = 1976 (1976 serial number range: A10,001-D25,000).
Old Mar 9, 2017 | 09:48 AM
  #118
bradlee hanks
Question
that's why I'm having so much trouble decoding this VIN because everywhere that I've looked it doesn't exist but it's on the trucks frame
Old Mar 9, 2017 | 11:06 AM
  #119
NumberDummy
I decoded everything except the series code, because there's no F77 listed (see pic below).
If you post a pic of the Warranty Plate (riveted to the left door face below the latch), I'll decode that too.
The TYPE/GVW aka MODEL code stamped on the Warranty Plate defines what the truck is.
Old Mar 9, 2017 | 12:33 PM
  #120
bradlee hanks
Unhappy
I wish I could but I don't have the cab
