Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
11 digit Vin decode
Old Dec 21, 2012 | 09:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by UGA_FX4
Thank you so much for the help, and yes I joined FTE just to ask you a question so I should have put you as a reference. You think these truck have any more value than their weight in steel? I want someone to take it that wants it rather than taking it to the scrap yard. THANKS agian!
Big trucks are a specialized market, so only a few will be interested. I'd stick it on craigslist and see what the response will be.
Old Apr 2, 2013 | 03:29 AM
blainechad's Avatar
blainechad
I have the same question I just bought a 1980 f250 and don't know how to decode the vin, the vin number is X26ZKJA4795. Thanks!
Old Apr 3, 2013 | 01:38 PM
NumberDummy
Originally Posted by blainechad
I just bought a 1980 F250 ~ VIN: X26ZKJA4795.
Welcome to FTE
X26 = F250 4WD Super Cab Pickup.
Z = 6.6L (400 2V).
K = Kansas City MO Assembly Plant.
JA4795 = 1980.
Old Apr 8, 2013 | 07:25 PM
lwt002's Avatar
lwt002
VIN help!
Dummy... You're skills are awesome!
Please help.
I have a 70's Ford F250 that I would like to have the VIN decoded on. I am interested to find out what the drivetrain is... Engine, trans, transfer case, axles... axles and engine mostly.
Thanks in advance for your help!!
F26HEY00301
Old Apr 13, 2013 | 02:32 PM
jkennedy's Avatar
jkennedy
Can anyone help me? I need to find out the year of this International moving van.
VIN - 416070H619922
Thanks!
Old Apr 13, 2013 | 07:54 PM
NumberDummy
Originally Posted by lwt002
I have a 70's Ford F250 that I would like to have the VIN decoded on. I am interested to find out what the drivetrain is: Engine, trans, transfer case, axles... axles and engine mostly.
F26HEY00301
Welcome to FTE
F26 = F250 4WD
H = 351M 2V
E = Mahwah NJ Assembly Plant.
Y00301 = 1977.
Trans/Axle codes listed separately on Warranty Plate.
Old Jul 11, 2013 | 07:31 PM
Captain Koe's Avatar
Captain Koe
I need help decoding a vin number. It's a step van.
Would like to restore this van but without the propper information can't do this.
Chassis is ford i think and the body a grumman olson.
There is no side on the internet that is able to decode 11 digit.
Vin: P50JVN72706
37 P500 0 G 44
J500 122 3400 8970218
Regards
Harv
Old Jul 14, 2013 | 04:03 AM
NumberDummy
Originally Posted by Captain Koe
I need help decoding a VIN - it's a P Series Parcel Delivery.
Would like to restore this van but without the proper information can't do this. Chassis is Ford and the body a Grumman Olson.
There is no site on the internet that is able to decode 11 digit VIN
VIN (Vehicle Identification Number): P50 J VN72706
W.B. 137 / COLOR: Blank / MODEL: P500 / BODY: 0 / TRANS: G / AXLE: 44 / MAX GVW LBS: 15000 / CERT NET HP: 122 / RPM: 3400 / DSO: 8970218 Verify, should only be 6 numbers.
Welcome to FTE
P50 = P500 (P Series Parcel Delivery).
J = Cannot be correct, not used after 1965. Possibly an A = 240 1V I-6.
V = Kentucky Truck Assembly Plant.
N72706 = 1972.
137" Wheelbase.
COLOR: Blank.
P500, 15,000 lbs. GVWR
0 = Body not supplied by FoMoCo.
G = C4 Cruise-O-Matic used with 240 & 300 I-6's, has 11 trans pan bolt holes.
44 = Rockwell model D100 Single Speed Rear Axle / 6.80-1 / 13,000 lbs. Rear Axle Capacity.
15,000 lbs. Gross Vehicle Weight Rating.
122 net HP @ 3,400 RPM (Possibly 240 I-6, VIN engine code A).
89XXXX: If 89 is correct = Transportation Service, last 4 numbers: Domestic Special Order.
If 870218: 87 = Selling dealer sold P500 to body company / 0218 = Domestic Special Order.
When there is no COLOR code, vehicle is painted a non standard color per original purchasers request, making the vehicle a Domestic Special Order.
2/2004: "She who must be obeyed" and I took a 14 night Panama Canal Cruise, Miami to San Diego. First port of call: Aruba
Old Jul 14, 2013 | 07:52 AM
Captain Koe
Thanks for the help. I posted some picture in my album. Maybe you can have a better look at the vin placard. Or this is my email harveykoeiman@hotmail.com.
Regards,
Harv
From one happy island
Old Jul 14, 2013 | 10:45 AM
NumberDummy
DSO: 970218
97 = Export.
4th digit of VIN appears to be a J, but what engine that is, I dunno. Cummins 855 cid I-6 diesel, 475 cid V8 not installed in P Series.
For a fee, you can get the info from martiauto.com, who has all the 1967/79 FoMoCo records.
Old Jul 15, 2013 | 09:38 PM
Pete Kildow's Avatar
Pete Kildow
Been trying to find a way to read my Vin # but have not found it yet.
Wondering if someone can help me out with it. If I go by what I find stuff does not match up.
I do know it was sold as a Cab Chassis truck then turned into a sleeper and hauler bed truck. It has the 240 HP 7.8 motor turned up RT6610 Road Ranger 10 speed, 4.56 rearend.
1FDXT84A1HVA59821
Pete
Old Jul 16, 2013 | 09:09 AM
NumberDummy
1FDXT84A1HVA59821
Pete
1FD = FoMoCo USA ~ Ford Incomplete Vehicle.
X = Gross Vehicle Weight Rating Class AIR 13,400-29,500 lbs.
T84 = F800.
A = Ford FTO 7.8L (476 cid) I-6 Diesel.
1 = Check Digit, FoMoCo use only.
H = (edit) 1987.
A59821 = 1987 Numerical Sequence of Assembly.
Old Jul 16, 2013 | 03:50 PM
  #28
Pete Kildow
T84 = F800.
H = 1988.
A59821 = 1988 Numerical Sequence of Assembly.
Thanks I see it shows 1988 but is titled as a 1987. Guess it was because of it being finished up somewhere else? Does the Vin # also show you what rear end and gears it has? Of is that on the numbers below the S/N #?
Pete
Old Jul 17, 2013 | 09:51 AM
  #29
NumberDummy
It is a 1987 .. 1988 was a typo.
VIN has 17 digits, how many didn't I decode?
TRANS & AXLE codes printed on Certification Label.
Old Jul 17, 2013 | 01:01 PM
  #30
Pete Kildow
NO you did a great job and thankful for the help. Was just wondering if the string of numbers below the SN was for the paint, axles and other stuff on the truck? Just got in a Specification book for a 1989 model. And I need to look though it and find out the rest of the info.
Again thanks for the time and help. Its priceless as your willing to take time to do this for people.
Pete
