Rusty
Old Sep 10, 2013 | 06:51 PM
  #601
bruno2's Avatar
bruno2
I wonder if the compressor is any good? Lets back flush the thing and fill it up. Of course the O rings need to be replaced. I have 10 or 12 cans of 134A at the shop. Sams was selling a case for $54.99 so I bought one and I had a few already. The back flush can be done with rubbing alcohol instead of buying the pricey AC flush. Do the bullnose trucks have a liquid line or do they have an orifice tube? I think I have some of the glow in the dark oil too.
Old Sep 10, 2013 | 07:02 PM
  #602
Gary Lewis's Avatar
Gary Lewis
Orifice tube. Not sure when I'll be ready to do the A/C, but I will install it all. However, it won't be with new o-rings, so the joints will need to come back apart, although that's easy.
But, I have no clue if the compressor is any good as there wasn't enough charge in the system when I got it to run, much less cool. Anyway, I'd sure appreciate the help when the time comes.
Old Sep 10, 2013 | 07:32 PM
  #603
bruno2's Avatar
bruno2
See if you can find a list of the O rings somewhere . Most of the time the parts store employees try to match them up with the old ones and that doesn't always work well. Advanced was trying to charge me like $60 for about $3 worth of O rings and a couple of them weren't the right ones. So maybe if we had some part numbers for the O ring sizes that would take all the guess work out if it.
Do you have a set pf gauges or a vacuum pump? If not I have gauges and I can borrow James' vacuum pump. The vacuum pump is very necessary IMO. With the pump we can pull the system down and let it sit for 30-40 minutes to see if it is holding the pressure and if not we know it's leaking before we throw the expensive refrigerant at it. Nothing like charging 3 or 4 cans in it to find out it's all leaking out.
Old Sep 10, 2013 | 07:40 PM
  #604
Gary Lewis's Avatar
Gary Lewis
I have the gauges, but not a pump. However, I've used a HF compressed-air vacuum pump that worked nicely, so might just get one of those. And, it is absolutely necessary to pull a vacuum and leave it a while since that's what boils off the moisture.
As for the o-rings, I'll check on that when the time gets closer. Good idea.
Old Sep 10, 2013 | 07:54 PM
  #605
bruno2's Avatar
bruno2
James has this oil injector that goes on the pick up line of the gauges and it injects the oil into the system as it charges. That way the oil gets everywhere instead of sitting in the bottom of the compressor.
Old Sep 11, 2013 | 04:16 PM
  #606
Gary Lewis's Avatar
Gary Lewis
Didn't have much time today as I boxed up a couple of E'brocks, did this and that, and finally got to Rusty. Got the seat belts installed, the fuel lines, and the tranny cooler lines. Which reminded me, Dad's truck had an auxiliary tranny cooler and since the steel lines are cut for the cooler I guess I'll put it on Rusty.
Any way, didn't make much progress but some. Took a lot longer to get the tranny lines on as one of the hangers goes to an engine mount hole and that didn't want to line up. Had to put the tall jack under the engine and loosen the mount bolts to get everything lined up. But, it finally did so tomorrow I'll install a few accessories.
Old Sep 11, 2013 | 05:01 PM
  #607
bruno2's Avatar
bruno2
Sounds like progress!
Old Sep 11, 2013 | 09:32 PM
  #608
truckertrav's Avatar
truckertrav
My .02..
I used a compressed-air vacuum pump on my 85..Worked great..
Pulled down vaccuum and left for 45min to hour...No loss...
New orfice, compressor,dryer, etc..
The O-rings and ALL parts from O'reilly's...Easy change from 12 to 134-A..
I think the O-rings were about 9 or 10 bucks...Came in kit and had all for the Complete system...No Problem..
Old Sep 11, 2013 | 09:46 PM
  #609
Gary Lewis's Avatar
Gary Lewis
Trav - Thats good to know that O'Reilly's has the o-ring kit. Think I will pick up an HF air-driven vacuum pump. Thanks!
Old Sep 11, 2013 | 10:00 PM
  #610
truckertrav
Yes,I got it all from them..I think you have the Factory Air and not Dealer..
I had a bad compressor,condenser,evap unit leaking , etc..
Needless to say I am VERY HAPPY with the NEW system...
I just put in the info on their website, shopped till I dropped, printed it out and took my list in and said "Can you fix me up at a reasonable cost?"
After everyone got back up off the floor from laughing, they got my parts..
Old Sep 11, 2013 | 10:33 PM
  #611
Gary Lewis's Avatar
Gary Lewis
I hope my systems, both Rusty's and Dad's, aren't that bad. Dad's worked about 3 or 4 years ago, but we ran out of R12 substitute and the leaks killed it. Have no idea when the last time was that Rusty's worked.
Old Sep 12, 2013 | 07:26 AM
  #612
bruno2's Avatar
bruno2
The good and bad aspect about A/C is that when they are broken a lot of times you can fix them for around $20. However, if not then it jumps to $500. There really isn't an between.
Old Sep 12, 2013 | 06:54 PM
  #613
Gary Lewis's Avatar
Gary Lewis
Got a bit done:
  • Vacuum lines hooked up, and a bad vacuum cap replaced that was probably causing problems
  • Throttle hooked up
  • After-market oil pressure gauge connected
  • DS-II connections made
  • Alternator and regulator installed - Rusty is getting the new alternator and regulator from Dad's since I'll put a 3G on it
  • Battery ground cable hooked up, a new block/frame wire made & installed, and the block/cab ground installed. Can't imagine how the tail lights worked before.
  • Regulator & alternator wiring harness changed out
  • Solenoid remounted. Can't understand how it had been working as the screws were totally stripped out and it was just hanging there.
  • Replaced the hood/cowl seal with garage door seal. (Soooo much easier to do with everything off the front of the truck.)
  • Heater hoses installed
  • The fuel pressure regulator mounted and connected
And, that leads me to pictures:
  1. The block & frame grounds, showing the new wire all properly soldered and with the attachment spots thoroughly cleaned and everything anti-seized.
  2. The old regulator/alternator harness. Note the crimped butt connectors, absolutely a no-no, and whatever kind of connections are in the taped joints. YUK!
  3. The remounted solenoid and regulator, with the replaced harness
  4. A shot showing the alternator, cowl seal, heater hoses, etc
Old Sep 12, 2013 | 07:15 PM
  #614
bruno2's Avatar
bruno2
You are moving right along Gary! Everything looks good too. Glad to see all the jimmy rigged stuff getting replaced . Rusty is getting some upgrades in the form of hand me downs from Dad's truck.
Old Sep 12, 2013 | 07:20 PM
  #615
bruno2's Avatar
bruno2
Are you running a 1406 on Dad's truck also?
