Rusty
Old May 22, 2012 | 07:26 PM
  #496
KingBigJoe's Avatar
KingBigJoe
Talking
Yay, the swap has started.
Old May 22, 2012 | 07:55 PM
  #497
Fordzilla80's Avatar
Fordzilla80
FWIW, cutting the carpet is a nightmare, even with a sharp knife. The under laying white cotton-like insulation doesn't like to cut.
Ask me how I know.
Old May 22, 2012 | 08:44 PM
  #498
Gary Lewis's Avatar
Gary Lewis
Yes, and I'm pleased. I'm sure you guys thought it would never happen.
Ask me how I know.
Not only is it hard to do but is DIRTY, with decades of dust et al in there. But, it kinda needs to be done as I don't think a hole in the floor or carpet will help it sell.
I'm thinking about moving the matched boots for the t-case and transmission shift levers from Rusty to Dad's truck and putting the factory t-case boot from Dad's on Rusty. That way the ones on Dad's truck would be matched, but the downside is that the t-case boot on Dad's doesn't have a trim ring and just comes up through the carpet so the carpet needs to be cut neatly. The ones on Rusty are cheap aftermarket, but they have a metal trim piece around the outside, so go down on top of the carpet.
Thoughts?
Old May 22, 2012 | 08:47 PM
  #499
Fordzilla80
The 1982-1986 trucks didn't have the trim ring either, so just make sure it's a close fit and you'll be fine.
I will admit, getting the shift boot into the hole in the carpet is a nightmare as well. Even though it's a square shape going into a square hole, it kinda acts like a square shape going into a circular hole.
Old May 22, 2012 | 08:56 PM
  #500
Gary Lewis's Avatar
Gary Lewis
I'm thinking I'll put the carpet in w/o the shift lever, mark the carpet, pull it, cut it, put the shift lever in, install the boot, and then install the carpet. But, I'll have to make sure the hole in the floor actually matches the boot, 'cause if I mark it and then the carpet doesn't fit closely.......
Old May 22, 2012 | 09:03 PM
  #501
bruno2's Avatar
bruno2
Well good deal! The swap starts!
Old May 22, 2012 | 09:20 PM
  #502
Fordzilla80
You know, I never thought about putting the boot through the bottom. That's probably how it's supposed to be done in the first place.
It's easier to flex the rubber boot through the carpet than it is to flex the metal support through the carpet.
Old May 22, 2012 | 09:30 PM
  #503
1983F1503004x4's Avatar
1983F1503004x4
So, Gary, it's time for the million dollar question. You touched on it before in the other thread I think, but I'll see if I can't plant that little bug back in your mind again.
You gonna keep KRusty?
Old May 22, 2012 | 09:47 PM
  #504
Gary Lewis's Avatar
Gary Lewis
NOPE! Can't justify two 1981 4x4 F150's. (But, when it comes time to haul rocks or other things that could mess up Dad's truck it sure sounds good!) Rusty will be in very good shape mechanically, and in fair shape on the body as there is no cancer. Let me rephrase that, Rusty has a skin rash but no cancer and few dents, so he could be put "right" fairly easily. He needs TLC.
Around here the hunters, of which there are many, look for trucks like this. They want them to start and run well. Quiet so it won't wake all the game, and four wheel drive and good tires so it can get in and out of the leases. Should be fairly easy to sell.
Old May 22, 2012 | 09:52 PM
  #505
Fordzilla80
Can't justify two 1980-1981 trucks? What in the world does that mean?
If I ever strike it well, I want at least three different 80-81 Ranger trim trucks in my driveway.
Some people collect Mustangs, I collect 1980-1981 Ranger Trim F-Series trucks.
Old May 22, 2012 | 09:58 PM
  #506
Gary Lewis's Avatar
Gary Lewis
I currently have 2.5 of them: Dad's; Rusty; and Brownie, although he's actually an early-build '82, so doesn't really count. And, I don't have anywhere near all of him as he's been a donor to many other trucks - his DNA is spread far and wide - even to Australia, come to think of it.
Old May 22, 2012 | 10:06 PM
  #507
bruno2's Avatar
bruno2
You need a rough truck to drive to the trading post out there in Podunk Gary. When the Native Americans try to jack you for your hydes that are supposed to be traded for your provisions let them beat up the rougher truck instead of Dad's. Rusty can handle the arrows and spears better than the other.
Old May 22, 2012 | 10:13 PM
  #508
Gary Lewis's Avatar
Gary Lewis
Actually, since Rusty is, well, rusty and sports Osage County plates they think I'm a local. Everywhere I go out that way they wave at me. Doubt that'll happen when I have Dad's truck all spiff'd up.
By the way, did you see my note in one of these threads re coming down on Thursday? Bringing a tailgate, or maybe two, and the t-case. Can you give James a heads-up? Or, send me his # again?
Old May 22, 2012 | 10:33 PM
  #509
Fordzilla80
Brownie doesn't count, he doesn't nor has he ever worn Ranger emblems.
Old May 23, 2012 | 04:33 PM
  #510
Gary Lewis's Avatar
Gary Lewis
Well, you guys keep saying that without pictures it didn't happen. So, here they are. Rusty is, as the line from one of my favorite musicals (Starlight Express) says, "scattered in a million rusty pieces down the track". Well, maybe not a million, but certainly over a hundred if you count all the fasteners in the baggies.
As you'll see from the To Do list, which is getting looooonger, I'm ready to pull the engine. But, that won't happen for a bit as we have plans for the next several days. You'll just about have waded through all of this by then and be ready for the next installment.
