Rusty
Sep 15, 2014 | 01:33 PM
Swapping radiators is simple Gary.
Brass ones can be easily soldered.
Sep 15, 2014 | 01:35 PM
Yep, swapping is easy. But, I'm not sure I want to just solder this one. I'm going to look around and see if we still have a real radiator shop. This is Dad's original 4-core and it might do quite well if it were boiled out and repaired where it needs it. But, if not then I'll find another all-aluminum one for Dad's when the time comes. Something big.
Sep 15, 2014 | 01:42 PM
You'll definitely be making more heat than stock.
Maybe it would be good to fix it.
It might be the only part of "Dad's Truck" left by the time you're done.
Sep 15, 2014 | 01:47 PM
You and my wife! Janey says I need to pick one bolt from the original truck and put it on the key chain.
Sep 15, 2014 | 01:50 PM
You said you didn't have any dirty, rusty bolts left....
Do it
for her .
She puts up with all this silliness.
Sep 15, 2014 | 01:55 PM
Good idea. So, should I powder coat it or leave it rusty? Bed bolt or valve cover?
Sep 15, 2014 | 01:59 PM
Use a valve cover bolt.
You don't want all that weight on your lock cylinder.
It's just not the same if you prep and finish it.
I would give it a quick shot of clear lacquer so it doesn't rub off on the pristine interior.
I think it will be a good reminder of just how far you will have taken this project!
Sep 15, 2014 | 02:03 PM
I do think that's a good idea, but I'm not going to tell her until the project is to the point I'm using the key. Thanks!
As for the lock, this isn't a GM! But, I fully agree and was kidding about the bed bolt.
Sep 15, 2014 | 02:14 PM
My keychain looks like I'm a janitor or a jailer.
I've worn out my cylinder before.
Eh... they are $10 to replace.
Sep 15, 2014 | 02:43 PM
I dislike anything more on the key chain than the essentials. Rusty's has his two keys, a shop key, and a house key. What I really like is the key/transmitter combo as they fit in the watch pocket of my jeans.
Sep 15, 2014 | 02:49 PM
I have 14 keys on my ring, and I use them all weekly...
Sep 15, 2014 | 03:29 PM
Quote:
Originally Posted by
FordFETruck
Better not do that on a GM vehicle!
Sep 15, 2014 | 04:14 PM
1986F150six
I do it to a Ford, Dodge, and a Mazda pickup. My dad has the same amount of keys, the Dodge and Mazda still have their original cylinder locks lol.
Sep 15, 2014 | 04:45 PM
We have one radiator shop left in Tulsa. It's on Admiral and just West of Delaware.
Sep 15, 2014 | 05:13 PM
Good to know, Bruno. Thanks.
