The camper thread! Pulling, using, equipment, maintenance!
Old Aug 8, 2017 | 07:26 PM
  #2656
pennsylvaniabo's Avatar
pennsylvaniabo
Mine is the same concept as this
https://www.etrailer.com/Weight-Dist...rt/C17057.html
Old Aug 8, 2017 | 09:11 PM
  #2657
Stewart_H's Avatar
Stewart_H
Originally Posted by pennsylvaniabo
My old friction bar anti-sway setup was like that (the weight distribution portion) and it worked well for the years I used it.
I use a Reese Dual Cam anti-sway weight distribution setup now.
Stewart
Old Aug 9, 2017 | 07:02 AM
  #2658
pennsylvaniabo
Stewart
Yeh, it's just bars and chains..I haven't used it as the hitch it permanently welding vs adjustable and way to high for my combination. I just dont want to spend $60+ on modifying it if the bars are gonna make it worse by unloading the trailer and not kill sway.
Old Aug 9, 2017 | 07:36 AM
  #2659
WE3ZS's Avatar
WE3ZS
So here is a quesion for the camper gurus. I have a built ex...v/b codes, timbrens, 30mm bar etc. I currently have a small camper 60's FAN single axle, 24' long. Its light and the Ex deoesnt even act like its back there.
The ISSUE is sway. It's a short, single axle trailer....yes I have as much tongue weight as possible, which laughbly hardly squats the ex at all. But make 65-70 she sways pretty good, add a semi or exp joint and it gets white knucle.
I do have an old WD set up with round bars. It would have to be modified for my trailer with a drop hitch and some custom brackets ($60-100). I currently tow it with just a simple drop hitch and ball. Would adding something like a friction sway controller work. The things are like $25 at harbor freight with a 20% coupon.
I almost thing the WD hitch wuld make it worse but unloading the front of the trailer more.
With how you are currently towing this single axle trailer, how level is the trailer? If you tow a single axle trailer with the tongue too high they tend to want to sway.
Old Aug 9, 2017 | 07:40 AM
  #2660
thor363's Avatar
thor363
Sounds like you need sway control more than weight distro. Weight distro won't help much with that issue. Single axle will amplify the way the trailer is loaded also. dual axle would help, and dual axle with more spread between axles even more so. What's your life worth? Money well spent to get some sway control.
Old Aug 9, 2017 | 07:49 AM
  #2661
pennsylvaniabo
trailer rides level when towed. yes it is single axle, not way to change that. Also not trying to cheap out, just not throwing money at something that wont fix it.
That is why I thought I would ask about a friction sway control as I dont need the WDH( it would actually make the tongue lighter)
Old Aug 9, 2017 | 08:36 AM
  #2662
thor363's Avatar
thor363
Not trying to offend, just saw too many Ex accidents lately and they don't end well. Good luck with your purchase! Adding sway control is worth every penny.
Old Aug 9, 2017 | 12:21 PM
  #2663
pgguru's Avatar
pgguru
when I am towing seeing other bumper tows going faster than me it scares me the most on the Highway... I'm always thinking (don't sway into me... don't flip in front of me... ) Last tow I was an F150 not even using WD bars
Old Aug 13, 2017 | 05:58 PM
  #2664
IMASAP's Avatar
IMASAP
Waiting in line to check in to the campground yesterday...... seemed like a good time to take a picture.
Old Aug 13, 2017 | 06:13 PM
  #2665
Toynut's Avatar
Toynut
Originally Posted by WE3ZS
Ok, go some help from my IT Dept (my son ) so hopefully these pictures will show up......
I recently bought a camper and was needing blocks for all the jacks. So when you posted your I liked them so much I copied yours and built a set thanks.
Last edited by Stewart_H; Aug 13, 2017 at 06:41 PM. Reason: Removed unnecessary, superfluous pics from quoted post for easier reading
Old Aug 13, 2017 | 07:58 PM
  #2666
mecdac's Avatar
mecdac
Looks nice, Scott.
Old Aug 13, 2017 | 08:49 PM
  #2667
WE3ZS's Avatar
WE3ZS
That's when I take a lot of my EX/TT pictures, when my owner is checking us into campgrounds. And of course, as always the wagon looks great Scott!
Old Aug 13, 2017 | 08:51 PM
  #2668
WE3ZS's Avatar
WE3ZS
Nice!
I think that you will really like them, they do speed up campsite setup and breakdown. Did you drill the million holes?
Old Aug 13, 2017 | 09:28 PM
  #2669
Toynut's Avatar
Toynut
Nice!
No extra holes for me only have a battery powered drill with weak batteries only drilled the holes for the handle ropes.
Old Aug 14, 2017 | 10:21 AM
  #2670
ExxWhy's Avatar
ExxWhy
Camped along the Ohio river last week. Leith Run, a small forest service cg. Sites a bit close together for my taste, but still a nice park. Have to reserve well in advance for the prime riverfront sites.
