I pull an 11K TT with mine and can hold 60/65 on most of the bigger Eastern highway grades in OD.
Having just driven from the west coast to the east coast, I can tell you that "bigger Eastern highway grades" do not hold a candle to the ones in the west. I didn't have to slow down once for a grade between Colorado and South Carolina. In California, Utah, and Colorado, I was in 2nd gear on some of those hills.
That being said, 35 seems a little on the slow side. What gears do you have? How much total combined weight were you pulling?
4.33 gears, although the effective ratio is a bit lower as I'm rolling on the 33.4" BFG 295/75r16 tires. The truck was empty save for two 200lbs riders and maybe 100lbs of gear.
Truck curb weight is the standard 7,200lbs plus some lbs for mods (sway bar etc).
The trailer dry weight is 6,440lbs, the max gross weight is 9,460lbs. Since i have not had the set-up weighed at the scales, let's just assume 9,000lbs. 40 gal fresh water tank was empty, but I was otherwise loaded up with lots of gear.
I suspect if if I had come into some of the gnarlier grades with a touch more speed and higher rpms/lower gears, I would have held a more respectable 45 or 50mph. But 60mph wouldn't be achievable I don't think.
I just can't think what would make an engine perform 40% worse than other folks' ex's in those conditions; feels like either the engine can pull, or it can't. Mo in between. Maybe vacuum leaks or fewer cylinders, but I had my mechanic do a full review. Recently changed all the plugs and boots etc.
Mark, that is true but with my 35" tires the effective ratio is 4.39.
And as Andy mentioned, my Eastern grades are a good bit easier than those out West.
im guessing user error/timidity!
I would suggest modifying your driving style to run the speed up a bit prior to the climb and to lean a little harder on the skinny pedal during the climb. Also consider some good custom tunes from 5Star, they wake the engine up a bit and make the trans work much, much better with improved shift strategies and pressures. The difference between the amount of throttle opening in stock tune and my 89 Octane Performance tune that causes a downshift out of OD is about 15%, pretty significant. I have never yet run at wide open throttle while towing with a combined weight between 18 and 19K lbs.
What do you consider wide open? Floored, red line? just curious,I'm no expert on engines and things. I try to keep it at 4000 on the hills, never over, and of course I prefer it at ~2000 on flat roads!!
Steepest grade in the US Interstate is I-24 in TN over Monteagle Mtn. 8%.
Out west they're longer and higher but none over 7%. My home on the ridge just outside GSMNP and is 10% grade... and I don't pull anything over 7K up there.
WOT (wide open throttle) means having the gas pedal floored, I never have needed to do that while towing with my rig.
With my 3.73's and our mountains I find myself WOT a lot with my TT with it downshifted to 2nd running 4500+ RPM. I'm almost always able to hold my speed(too fast). But I do start speeding up before a big pull as to not drop below the speed I want to run. If you work the ol girl she'll do it no problem like most of us know. I for one am not afraid of it sitting at almost 5k rpm for as long as it takes to crest the incline. I know for some reason this scares people
In theory, the computer won't let it run over redline.
Exactly, If i recall correctly with my SCT3 Tuner I upped my shift RPM at WOT to 5,000 RPM with no ill effects in the last 7 years and 40k. I drive it pretty hard all the time with a lot of full throttle runs (stop lights, on ramp..ect).
The transmission and engine computer will not let you over rev the engine. It's not a manual transmission so let it rev!
Example of putting my foot to the floor and letting the truck do the work.
Leaving work in a few to go home, grab the Ex and camper, wife will grab the Dodge and the boat and we are taking the 30 minute drive to the lake for a couple of days.
Sounds like recipe for a great weekend, have fun!
We are currently in the UK and I am amazed at the large number of caravans (camping trailers), motorhomes (Class A, B and C) and a great many campgrounds and dry sites along the roadways. Looks like it would be a great way to see this beautiful countryside.
