New 71
It died right at the end of me seeing what I needed. We ended up loading it on my trailer with a backhoe.....then the fun began. I had to figure out what the PO did, then talked to the PPO and got even more info on it.
It rough, but its a fun rig. I do not cringe when I bump something, I just hit the skinny pedal. It climbs like a mountain goat on crack! lol
After the hinge mod it will now open even with a roll bar and not have to be cut.
Some times its the little things in life that are nice....like to not have things fly out the glove box.
I had to trim off a little more of the one side of the hinge left over and just used a coat hanger as the complete hinge rod. I did not cut the R/H side hinge only piece like in the diagram.
Pop it open a bit, slide it left to clear the roll bar, wala.
In the diagram it shows to cut off a small piece of the bottom tab. I cut complete tab off on the bottom of the dash and did not cut the "right hinge only".
And ditch the springs and use a coat hanger for the rod from outer edge to outer edge.
The red 71 body does have the white Safety Standard Certification Label was introduced in 1970. It was glued to the B pillar (door post) below the striker plate on trucks and above the door striker on EB's.
Some notes I found on other EB sites: I broke the stub shafts on my '73 Bronco more times than I want to think about. I installed CrMo shafts and CTM joints and still broke them running 35" MT Baja Claws and ARB lockers (302, NP435,Dana20, ARB air lockers, 5.43 gears).
I finally figured outwhat was causing the breakage. The factory steering stops were set atabout 52 degrees. Spicer rates their joints at 40 degrees. I installed longer stops on the steering arms and never broke another stub shaft. SET YOUR STEERING STOPS PROPERLY!!!!
AxleShafts There are two common types of regular duty Dana 44 shafts, those with small u-joints and those with large ones and I got one of each. The stock shafts for the early Bronco Dana 44 have small u-joints, but the short one (driver's side) can be directly replaced with a shaft from an F150. The F150 shaft has the large u-joint, and some body had already done that with my front end before I bought it. Cool! Unfortunately there's no such easy upgrade for the long side shaft, so I'll just have to keep an eye on it. One option to upgrade the long side is to cut down and re-spline a F150 long side shaft, but that's more ca$h
A Dana 44 front axle from an F-250 would probably have bigger brakes, but I'm not sure what else would actually ne bigger / stronger. It is still a Dana 44.
And to do it you'd need to deal with a bunch of things: 8 lug wheels that wouldn't match the 5 lugs in the rear, a wider track width, and probably the biggest, converting the axle from leaf spring to coil spring with radius arms and a track bar. It wouldn't be real easy to do well, and for the small gains going from one Dana 44 to another I wouldn't bother.
But I do think that almost all Ford front axles in the '70s were high pinion, so I don't think you'd need to be too lucky for that. Although I could be wrong about that.
The current front axle has already been disk brake converted, has a locker and has the F150 steering box swap done.
West Coast Broncos
If I want to "go big or go home" I would but one of my 2 spare front D60's I have setting around under the front and put a D60 or even a 14 bolt in the rear....or maybe the other steering D60 under the rear end and go all steer!
I am not that motivated or have that kind of time, hell I can't even get the red truck finished up and that is where one of the D60's is supposed to go anyway.
And the other one is slotted for another project....
And I am hopefully selling some parts to a fellow EB owner.
dclack - on here (& sometimes over at CB) has helped me for these kinds of Qs. May B away 4 the 4 holiday?
CB on the "search function", or just a straight out "question post" over there.
Please post a link or just say the place I need to go. And it is a F150 shaft in question.
I also found out or am pretty sure that the passenger side axle shaft is not the stock small ujoint 73 Bronco D30/D44 shaft. But is the larger ujoint 78/79 Bronco/F150 larger diameter, 19/30 spline axle shaft.
I am checking with a machinist buddy on shortening and re-splining a long passenger side spare out of the front axle of my parts Bronco, so I will have both side trail spares.
While checking my steering degree limit bolts, so not to blow a new u joint, I found one broken. And then I found a tie rod end is loose, the tie rod end is good, the play is where it goes thru the (chebby?) knuckle/steering spindle, which I think is a swap job, I need to re-sleeve it.
I have 5 bolts that hold the spindle on and not 6, and the tie rod is on top not on the bottom like a stock Bronco...?? Still learning as I go and learning what else the PO did.
And in the pics the shaft on the bottom came out of my 73 Bronco and the 2 on the top came out a 79 Bronco.
The '78-79 Broncos are full width, hence the longer passenger side axle shaft. I'm sure you already knew that, so maybe that's not the question you were asking.
As for the tie rod over, I'm guessing that someone reamed and sleeved the knuckle for the swap.
