1966 - 1977 Early Broncos
New 71
Old Feb 20, 2016 | 10:39 AM
  #166
chrlsful's Avatar
chrlsful
"Flat/Nasty" hada pic so I could see ROCK
beadlock sense;
"Seymoure" - no pic (only closed 2 mo a yr!) but now I get the idea for the beadlock/air down. More fun!
Love that 417/870 Area Code!
Old Feb 20, 2016 | 07:58 PM
  #167
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Got the new tires and rims put together today. Hope to get them on tomorrow.
Old Feb 21, 2016 | 10:26 AM
  #168
chrlsful's Avatar
chrlsful
bead lock
just locks on outside bead?
what bout inside bead? no need there?
Old Feb 21, 2016 | 10:46 AM
  #169
77&79F250's Avatar
77&79F250
Correct, these are not double beadlocks and or do not have a internal insert.
I have 16 bolt beadlocks and 35's on it now, but the boggers are about shot.
So I double upgraded.
Old Feb 21, 2016 | 11:16 AM
  #170
Nothing Special's Avatar
Nothing Special
Double beadlocks are out there, but pretty uncommon.
The thought is that the main way you lose a bead is by putting too much torque to the tire and spinning the rim in the tire. A single beadlock is plenty to address that.
The second most common way to lose a bead is to push the tire sideways. The outside front tire gets that worst in a turn and the downhill side tires get it worst on a side-hill (weight transfer is away from the other side in both cases). And it's only the outside bead you're going to lose in either case.
Old Feb 21, 2016 | 11:21 AM
  #171
chrlsful's Avatar
chrlsful
kouwell
'preciate the 2 responses.
Old Feb 21, 2016 | 11:50 AM
  #172
77&79F250's Avatar
77&79F250
Thanks Bob for the explanation.
Old Feb 21, 2016 | 07:50 PM
  #173
77&79F250's Avatar
77&79F250
Got them mounted up, I need to do a flex ck and see if the sawzall needs to come out.
Old Feb 21, 2016 | 10:03 PM
  #174
chrlsful's Avatar
chrlsful
glad 2 C the tools
AND
spare R still there.
Enjoy all ur labors,
let others drive now'n then !
8-0
Old Feb 22, 2016 | 07:19 AM
  #175
77&79F250's Avatar
77&79F250
I will probably ditch the 35" spare for better out the back viewing anyway. The tool boxes are staying for sure. I would have to work over the back half of the roll bar to get a 38.5 spare fit in between the down bars.
Shortening up the rocker panels, adding rock sliders and working over how the the roll cage is tied to the frame better, is next on the list.
Old Feb 23, 2016 | 08:38 AM
  #176
chrlsful's Avatar
chrlsful
"...Shortening up the rocker panels,…"
'Shoring' up - means strengthening
'Shortening' up - means reducing the over all wheel base?
No comprende`. These lill bobtails need lengthening if U ask me (hwy driving, towing, on board hauling).
Old Feb 23, 2016 | 09:43 AM
  #177
dclack's Avatar
dclack
This should explain what he means... LoCoFoMoCo Racing's Rock Skis
Old Feb 23, 2016 | 11:42 AM
  #178
77&79F250's Avatar
77&79F250
And or like this. Cutting off Rockers | ClassicBroncos.com Tech Articles
And this BroncoFix Rocker Panel Replacement Party :: For the 1966-77 early Ford Bronco
I am looking for one more great explanation and way of doing things..
Old Feb 23, 2016 | 08:35 PM
  #179
chrlsful's Avatar
chrlsful
"...Shortening up the rocker panels...
On my ride home just now I thought of nuther way, increasing wheelwell size.
I'll check the 2 links - may B that's what's meant.
Old Feb 23, 2016 | 09:09 PM
  #180
Nothing Special
Nope, it's cutting the bottom off the rocker (shortening the height, not the length) and then replacing it with some tubing. Gives more clearance for rocks, bets rid of a (usually) rusty piece of sheet metal and replaces it with something that can take it's knocks as a rock slider.
