1966 - 1977 Early Broncos
New 71
Old Apr 12, 2014 | 06:44 PM
  #106
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Thanks, yes its 7 kinds of fun on Sunday.....but out riding out in a back 40 pasture you have to watch out for fresh cow business.
Old Apr 13, 2014 | 07:56 AM
  #107
chrlsful's Avatar
chrlsful
transmis/transfer sift levers
Thanks for the help naming it
My used but original 3 spd shifter came in today, so I can ditch the PO home made twin stick goofy set up. That is not user friendly, by no means.
Kind of a mouth full name - anyway,
the twin stick looked painful! but Y the transmission shift change. (I guess I forgot how it looked...
Old Apr 13, 2014 | 08:02 AM
  #108
77&79F250's Avatar
77&79F250
Well after getting the 3 spd set up in the mail and doing some more detailed looking around under and in there it seems that with the power brake booster and master cylinder moved to under there there might no be room for it....
They took the hard route to make this thing with lots of custom "WTH is that set up for" stuff, but its fixable for the most part.
They totally removed the body and dash and had to fab/cob up the clutch and brake pedal mount. Looks like that led to the twin stick set up, so now I get to reverse fab that mess.
Old Apr 15, 2014 | 09:12 AM
  #109
chrlsful's Avatar
chrlsful
Well, I don't think yer gunna raid ol red for help. How bout the '68 parts you got awhile ago? Could they go on hillbillybug to solve anything? Seemed they were mostly sheet metal... most needed would be a firewall assembly type thing offa bronk. I'm too far away - but gotta get rid of my spare, too bad we couldn't swap for a front bench.
Old Apr 15, 2014 | 08:04 PM
  #110
77&79F250's Avatar
77&79F250
None of the spare body parts I got will work, there is none of the body left.
Old Apr 16, 2014 | 08:44 AM
  #111
chrlsful's Avatar
chrlsful
room for the mailed 3 speed set up
seems like U got everything- doors, hood, w.shield, top- but what U need:
"...a firewall assembly type thing..."? may B not...
Why change the transmission shift? That looks pretty standard...
Old Apr 16, 2014 | 09:42 AM
  #112
77&79F250's Avatar
77&79F250
The j shift xfer case is ok, but the twin stick 1st-reverse then 2nd & 3rd is the other 2 levers.
It is not really good for any type of "speed shifting", when I grab a lever and tack it out, I want to roll right into 2nd, without changing levers.
I got an original 3 spd floor shift, just need to mod it into place. The master cylinder and power brake booster are under the floor now, and right next to the trans/xfer case.
Old Apr 18, 2014 | 06:58 PM
  #113
77&79F250's Avatar
77&79F250
Made the seating arrangement a little more comfortable and safer in the hillbilly-bug.
Old Apr 18, 2014 | 07:33 PM
  #114
grinnergetter's Avatar
grinnergetter
Dagumm Rich...you got all the toys.
Old Apr 18, 2014 | 08:22 PM
  #115
77&79F250's Avatar
77&79F250
Yea and all the long hard days being gone from the Miss's, working in far away places to go with it.
You got toys too, I seen your tractor.
Old Apr 18, 2014 | 09:16 PM
  #116
grinnergetter
Check out my grandpa's ****** I got from my dad. Pics are in the CC build in the bump section...."Finally own a crew"
I'm just trying to keep pace with the cool kids.
Old May 23, 2014 | 03:27 PM
  #117
77&79F250's Avatar
77&79F250
Well I finally got the ball rolling to replace the splendidly **** thin wall back half wanna be roll bar. It was more like a "light bar" and no way near strong enough to be safe.
We are replacing it with proper roll cage material and carrying it towards the rear to be like a family cage. I am trying to work it so I still have the fenderwell tool box's.
Also going to tie it all to the frame and rear bumper, after a possible rear bumper upgrade?
Pics after the job is done.
Old May 26, 2014 | 12:29 PM
  #118
77&79F250's Avatar
77&79F250
Well we got the relocated roll cage (out of the 79) modded and installed into the 71 along with a new rear bumper put on it and tied into the roll cage.
Will get the middle bars and front bars tied to the frame here soon.
Same bumper style going on the front, and making rock sliders and tying them into the frame too.
As always thanks to a fellow FTE member for the help.
Old May 26, 2014 | 05:08 PM
  #119
77&79F250's Avatar
77&79F250
A few more...that rear bumper is not going NO where, it is welded to 2 1/2 x 2 1/2 heavy gauge square tubing and put inside the frame rails.
Welded to the top part of the frame, will be grade 8 bolted thru the top frame rail thru the square tubing and then thru the bottom frame rail.
The replacement front will be just like it. I will post some pics of the tie in to the frame with it.
Old May 27, 2014 | 12:31 PM
  #120
chrlsful's Avatar
chrlsful
Great design for roll cage on "Red", that'll B the luxury ride. Safe 4 kids?
Just watch the sparks down that right pant leg. Caught my sox on fire that way...
HillBill Bug will be for the tougher courses?
