- factory retarded cam timing
- Building a mild 400: suggestions ?
- '71 400 piston picture
- 351M cam suggestions
- 400 conundrum....
- Oil pump
- Found coal under the valve cover
- 460-351m swap immediate answers welcome
- Emission vs. Non Emission
- 351m/400 oilling problems?
- 6.6 base timing set to 13deg. & Vac advance = 48deg!!
- safe way to remove rust from rod journals
- c6 trans
- rattling under the valve cover
- Robertshaw 333-xxx vs regular thermostats
- Can't get intake gasket to stop leaking!!!
- 400 engine for sale
- 400, 460, 429, clutch, swap
- What size fittings for external oil line?
- Edelbrock heads in classified
- ford 400 cam and timing
- Edelbrock head value??
- need advice to decision about my 400?
- This damn 408 will not stay timed!!!!!!
- 1977 400 cams?
- droping in a rebuilt 78 motor in my 79
- low fuel at idle
- Oil Pressure
- Difficulty Timing my Engine
- How to clean out the block?
