Comp Cam 284 roller
Old Nov 23, 2019 | 03:42 PM
Sprettur's Avatar
Sprettur
Comp Cam 284 roller
Hi i have a off road truck with a 408 10.6:1 compression and AFD 4V alloy heads. I am wandering about the Comp 284 hyd roller cam 224@50 566 lift how it would work with this setup its listed 2000-5500 rpm probably for the 351c so how would the power band be in the 400 ?
Old Nov 24, 2019 | 01:28 AM
SDDL-UP's Avatar
SDDL-UP
I ran the numbers and that cam would peak at 4,826RPM for a 400 if it's listed at 5,500 for a 351C. That's based purely on the difference in displacement. It's possible the 1/2" longer stroke of the 400 could make it peak even earlier, but I'm not sure how you would calculate that. Sounds like a fun off-road truck to me!
Old Nov 24, 2019 | 07:24 PM
Sprettur's Avatar
Sprettur
Okey so i could go with a larger cam i would like the power band to be about 2000-6000 its a light truck with 44" fun country and 5:13 gears NP-435 manual.
Old Nov 25, 2019 | 11:33 PM
SDDL-UP's Avatar
SDDL-UP
You should have plenty of cylinder head. I'd get the flow numbers and call a cam company for a recommendation.
Old Nov 27, 2019 | 11:32 AM
SDDL-UP's Avatar
SDDL-UP
Okay... So I have Engine Analyzer Plus, a very nice computerized dyno simulator by the way, and I ran the AFD 4V heads on a 400 with 10.6:1 compression and a "guesstimation" of that camshaft. It looks like you can get to 6,000 RPM and would be making just over 500 HP if everything were optimized. If you had the cam card information on the camshaft I could be more accurate.
Old Nov 28, 2019 | 08:22 AM
BrutalBronco's Avatar
BrutalBronco
284HR Specs
IMO this single pattern HR is a conservative profile, but should clean knobby tires with a measure of reliability.
Old Dec 1, 2019 | 08:45 PM
Sprettur's Avatar
Sprettur
I will be running the AFD 4V alumium heads ported Edelbrock rpm air gap manifold ported forged pistons with floting pins dobble roller cam plate roller comp cams roller rockers headers and u get the idea
hail destroyer
27
Jan 8, 2019 05:06 PM
Old 4x4
Mar 30, 2010 06:24 AM
MBBFord
Jul 24, 2005 02:06 PM
Greg 79 f150
May 31, 2005 05:27 AM
mstum00
Jan 10, 2005 09:46 PM
