- bent valve symptoms?
- Reliable Source for Remanufactured 4.6L Longblocks?
- 5.4 Stalled then hard restart
- 2002 4.6 idle problems
- turbo 5.4L
- 4.6L leaking antifreeze
- Need Someone's Wisdom
- How Do You CONFIRM A Leaky Head Gasket?
- 5.4l Sohc ???
- Misfire No Check Engine Light
- 5.4 rebuild help
- Less Exhaust Back Pressure Means More MPG, Right?
- 5.4 Miss
- Rebuilding the 97 4.6
- What years of 5.4 are interchangeable with a 2000?
- 4.6 or 5.4 what should i get
- Knocking sound on a 1999 5.4 F150
- 98 4.6 in a truck same as 91 4.6 in a crown vic
- winter and a heater?
- 4.6 econoline chugging
- 5.4L Spit Plug Problem
- Got an Update from MSD
- Check Engine Codes
- To change or not to change?
- 5.4 oil leak not sure were
- While I'm in it, what should i do?
- 97 5.4 exhaust manifold stud rusted off
- 97 5.4 to 99 or newer 5.4
- Head Swap
- cold idling problems
