It means Bank 1 and bank 2 are lean acording to the o2 sensors
It can be fuel delivery or a a leak in the air induction after the maf or leak at the pcv valve hose .
Also could be intake o-rings.
Well replaced fuel filter, PCV valve, cleaned the MAF sensor and code still there. Looks like time to change the hose from the PCV valve and elbow. Anything else worth changing before taking to the dealer?
Thanks.....
