5.4 Miss
Old Dec 8, 2006 | 08:54 PM
hush210's Avatar
hush210
5.4 Miss
My work truck(a 2000 E-250 with a 5.4 and an auto) started missing the other day. Im planning on new plugs and wires bu is there anything else that could cause it to missfire?
Old Dec 8, 2006 | 10:57 PM
LxMan1's Avatar
LxMan1
Yes, the common problem is a COP (Coil On Plug)
Is you check engine light on? If so, have it scanned and it will tell you which cylinder is missing. That coil is probably bad.
Old Dec 9, 2006 | 07:37 PM
hush210's Avatar
hush210
The check engin light came on after it started missing. Is that what they do?
Old Dec 9, 2006 | 08:11 PM
Wilber15's Avatar
Wilber15
If you know the cylinder missing, swap the COP from the bad cylinder with a cylinder next to it and see if the misfire moves to that other cylinder. If so, you know it's a Coil On Plug. If it stays, it's either a injector problem or mechanical problem(valve/piston/ring)....
Old Dec 10, 2006 | 04:06 AM
LxMan1's Avatar
LxMan1
Yes, the check engine light will light. Run it by AutoZone for a free scan and post the code here. We can decifer it for you.
Old Dec 24, 2006 | 02:37 PM
Galveston Yankee's Avatar
Galveston Yankee
Also check your air filter. A disruption in air flow will cause it to miss.
Old Dec 24, 2006 | 07:33 PM
projectSHO89's Avatar
projectSHO89
Very unlikely on a computer controlled engine.
Get the codes read. They are your next clue in the diagnostic process.
Steve
Old Dec 31, 2006 | 11:39 AM
redford's Avatar
redford
FTE Leadership Emeritus
I disagree. I have seen it happen on poorly maintained vehicles. The engine tries to compensate for the lack of air by restricting fuel, keeping the F/A ratio good. Eventually your weakest cylinder will start misfiring . Soon the computer cannot adjust the F/A ratio to keep it in tolerance, you get a rich mixture at that point.
It's one of my pet peaves with modern engines, they mask bad maintenance pratices. The engines run good until the computers can no longer compensate, then the people think they have a sudden breakdown and blame the engine.
In any case, pulling the air filter will tell you right away if this is the problem, but with these engines a COP is the likely cause.
Rpayne
Jul 13, 2009 10:28 PM
dantsg
1997 - 2003 F150
Oct 31, 2008 08:36 PM
joe911
Modular V8 (4.6L, 5.4L)
Aug 1, 2007 04:45 PM
mustangmike
Aug 4, 2006 07:03 PM
kerdog99
Nov 3, 2004 05:39 PM
