- 3 wire O2 conversion
- 86 idi with 4speed
- valve stem seal?
- Rewiring 82 F150
- Clifford Intake / Weber 38 Carburetor
- 1985 F150 302 holley problems
- 4.9L - 300 I6: more power kit, anyone looking?
- Not a bullnose, but a new member of the family
- 2100 fast idle cam source found ?
- Shift lever doesn't always move to the correct gear
- Brake Backing Plate/Dust sheild
- 302 is a dog
- Oil delima 86 f350
- E-Brake Cable hookup AFTER 3" Body Lift?
- EGR vs. Non-EGR
- Holley 4548 / Ford 300
- Front brake upgrade?
- no dash lights or tail lights
- 86 F350 Rear Brake Anti Skid Valve
- At a crossroads with my 86
- Headlight switch and wiring
- change fuel tank from 19 midship to 16 gallon midship
- 2wd or 4wd lift kit?
- Quick question about belt replacement
- just checking in, new guy with Diesel question
- batterys
- heat tube?
- 4.9 Rebuild
- Away bar brackets
- What made you want a Bull Nose? Share your story here:
