- 96 explorer
- AC seem to be always on
- Climate Control Vacuum Diagram?
- 1998 Explorer 4.0 Missing bad and getting worse
- 96 Explorer 4.0 loosing anti freeze, no leak?
- 03 Explorer oil change
- Overhead Console
- popcorn sound in 4.0
- '97 Explorer Sport AC fail
- 1997 Ford Explorer dies upon letting off gas at stops Someone please help!!!
- Rear Axle Info
- Differential questions
- Sunroof flies off on highway
- Starting Problem!?
- Replacing an input shaft on 94 explorer 5spd
- 2002 Explorer (clicking in front bearing in turn)
- buying a 05 explorer
- MAF or What?
- 95 XLT - two power windows work, 2 don't
- 98 Explorer, horn problem...
- Low idle/low speed shutter
- 2000 Explorer Horn & Cruise Won't Work
- 05 Explorer Trans issue
- 04 Explorer With FF Flexible Fuel Compatible???
- Metallic Rattling Noise/ Power Loss
- 2003 Explorer 4.6 Timing Chain Noise
- Can Ethanol blend cause CEL
- DPFE Sensor-Outrageous Price
- Does you explorer do this????
- 94 4.0 Timing cover Gasket
