Can Ethanol blend cause CEL
Old Jun 20, 2005 | 03:30 PM
hank_48's Avatar
hank_48
Just drove to Minnesota from KC and back. Was pulling a boat with my 97 EB 5.0. Had no problems on the way up but on the way back the CEL came on in Iowa. Car ran fine the whole trip. I use the middle grade of gasoline (89 octane) when I pull the boat for long distances. But Iowa has an ethanol blend for that grade. I"m wondering if that may have caused the CEL. This has happened every time I drive back from Minnesota thru Iowa. But never on the way up...
Anyway, could gasoline blend this be the culprit?
Old Jun 20, 2005 | 03:48 PM
Trucountry's Avatar
Trucountry
If im not mistaken the CEL is usually due to a O2 sensor so more than likely the blend would cause the error.
Old Jun 20, 2005 | 06:32 PM
Jharger's Avatar
Jharger
Fuel blends have longer term affects like trashing the cat. More likely that you put the car into a condition it's not normally seeing in this long drive. Pull the code. You need to find out what happened and then decide if there's something that needs fixing. A CEL should not be ignored. The light doesn't have to stay on for there to still be a problem. Most of the time it will flash once and then store the code, not to light up again.
Old Jun 20, 2005 | 08:09 PM
mvoeller2's Avatar
mvoeller2
I run ethanol blends all the time and have had no issues in any of my vehicles. Like previous poster said, see what code it set first.
