04 Explorer With FF Flexible Fuel Compatible???
The 04 Explorer i bought is Capable of using Flexible Fuel (I only use regular unleaded, we don't have the ethonal mix around here). The question i have is are the computers de-tuned just incase you use something other than regular unleaded? I have a sticker under that says something about the computer. I can get the code from the sticker if that helps...
Thanks...
Thanks...
Might have been a "technical service bulletin" for the original PCM & the dealer has swapped it.
Click on "recalls & technical service bulletins" at www.alldata.com, then enter the info for your truck & see what you come up with.
If all else fails, check with the dealer.
