- Vibration in 5th gear
- REAL Differences between models, Towing Package info
- Spark plugs lighting up
- 351w or 460???
- ok guys 95 f150 4.9 l6 trouble
- Turn signals 1990
- transfer case conversion
- D60 SWITCH
- Can I do
- 460 Idle EFI
- 95 5.8L occasional surging idle, esp. when cold
- Best 92-96 fenders and core support question
- 1990 460 starter seized
- 1989 F-150 Lariat EFI Stalls shortly after starting
- Paint codes
- problems with the starter on 94 f150 with a 300 6 cyl
- lack of power on '89 4.9L/I6. Where to start?
- MAF Conversion
- Top Leak ZF5 S47 96 Powerstroke
- Almost done!
- 1989 F250 Lariat Factory Electric Brake Harness Wiring
- Severe shudder !
- adding sway bars
- 1995 302 pinging and missing!
- 302 Oil Pressure Sending Unit
- 1986 5.0 Miss at idle and skip under load
- life expectancy of a 460?
- 1992 Nite 5.0 idle problem
- 1996 turn signal schematic needed
- Having some Speedometer cable issues
