Vibration in 5th gear
Old Mar 24, 2015 | 07:45 AM
gravydude's Avatar
gravydude
I've started to notice a vibration in my drive train. I notice it a little at 45-50 mph, but when I shift into 5th gear I notice it more. No matter how fast or slow I drive in 5th, I notice it. If I push in the clutch, the vibration stops.
I don't know if it's the trans, U-joint or an unbalanced drive shaft?
Any thoughts on this would be appreciated.
Old Mar 24, 2015 | 09:14 AM
gravydude's Avatar
gravydude
I probably should have told you what truck I'm talking about
1995 F-150 XL
5-spd 4x4 300 I6
Cheers!
Old Mar 24, 2015 | 09:52 AM
im2tall33's Avatar
im2tall33
There is a good chance that you have sloppy u joints. At least that has always been my case when I have had vibrations like you are talking about.
Old Mar 24, 2015 | 10:30 AM
gravydude's Avatar
gravydude
Last July I was under the truck and noticed the weight block was missing from the drive shaft (fresh metal area). I don't know if this is related or not.
I don't know if now I'm just noticing it?
Maybe I could take the drive shaft out and have it checked for balance?
Cheers
Old Mar 24, 2015 | 12:00 PM
Phy's Avatar
Phy
Yeah, I'd check that drive shaft, but by the symptoms you report, the vibration you're feeling isn't that. A drive shaft or u-joint will cause vibration at particular speeds regardless of what gear you're in, engine speed, or whether or not the clutch is dis-engaged.
Try getting it to vibrate, then push the clutch in while holding engine RPM the same as with the clutch out.
Old Mar 24, 2015 | 12:52 PM
gravydude's Avatar
gravydude
I just tried this:
It stopped as soon as I pushed in the clutch. I tried to keep the RPM's about the same. I even when I revved the engine, the vibration didn't come back.
It seemed to taper off when I got the truck up around 65 mph.
Thanks for the direction!!
I was just fearing the worst (trans)
Cheers to all ya!
Old Mar 25, 2015 | 12:54 PM
Phy's Avatar
Phy
Boy, a strange set of symptoms...
Maybe someone else will chime in with an idea.
Old Mar 25, 2015 | 02:00 PM
gravydude's Avatar
gravydude
I found the universal joint closest to the trans was loose when I push up and down.
I tried giving it more grease, but it wouldn't take it.
So I just took it to the shop.
Hopefully replacing this will help?
Old Mar 27, 2015 | 07:26 AM
gravydude's Avatar
gravydude
The problem is the yoke. The hole is slightly bigger than the U joint. So now I need to either replace the drive shaft (long part) or get one from a junk yard.
Does anyone know if other Ford trucks would have the same drive shaft?
There’s a 93 Ford 4x4 F-150 with a an automatic at the local yard with a drive shaft.
Does anyone know if this would work for my truck? I’m thinking of getting it and swapping the short end if I have to.
Cheers
dines78
Dec 10, 2012 07:35 AM
f15097
1997 - 2003 F150
Jul 17, 2010 08:54 PM
batesfarmer
Jan 16, 2007 06:19 AM
Stephan
Aug 23, 2002 01:23 PM
