1992 Nite 5.0 idle problem
Old Mar 22, 2015 | 04:50 PM
TheV8tractor's Avatar
TheV8tractor
I just bought a 92 reg cab flareside 4x4 nite and im having an idle problem. The truck runs and drives great. But when ever the truck is revved the idle slowly floats back down to the correct idle rpm speed. This kind of creates a problem while driving because it doesn't seem like I can shift very fast. Ive been told a bad Idle Air valve but I would like to see what you guys think, thanks
Old Mar 23, 2015 | 03:33 AM
TexasGuy001's Avatar
TexasGuy001
It sounds like the IAC or the TPS to me.
Old Mar 23, 2015 | 07:56 AM
MtTheJeffro's Avatar
MtTheJeffro
had the same truck in a 4x2 model. awesome vehicle...
are you saying the idle hangs up and then slowly drifts back down? if so, I had the same problem even after changing out IAC and TPS. Also a dead/leaky gasket at the throttle body can do this.
I wound up throwing a heavier return spring on the throttle cable and it helped considerably.
Old Mar 23, 2015 | 10:43 AM
TheV8tractor
Thanks for the replies! I just bought a new IAC and will put it on tonight and let you guys know. The idle sometimes sticks a little bit when its cold out but when its 40F+ it never sticks it just slowly idles back down. And while im driving the check engine light may come on for about 15 seconds and turn off.
Old Mar 23, 2015 | 11:22 AM
rla2005's Avatar
rla2005
The computer is telling you there is a problem. Read the codes.
Old Mar 23, 2015 | 03:11 PM
TheV8tractor
Can the codes still be read at idle? The light only comes on for a brief time while driving and never at idle.
Old Mar 23, 2015 | 03:49 PM
miguel.in.az's Avatar
miguel.in.az
The codes will store in memory so you can read them without the truck running
Old Mar 23, 2015 | 04:28 PM
rla2005's Avatar
rla2005
X2...
Old Mar 23, 2015 | 04:29 PM
rla2005's Avatar
rla2005
Warmup the truck then do this: How To run A Self Test
Or purchase a code reader such as the Equus/Innova 3145.
enzer2406
Feb 18, 2011 01:39 PM
fire232
Sep 16, 2003 08:44 PM
spider42
Jan 24, 2003 12:54 PM
