- Fuel pressure transmitter install
- Air Cleaner question
- Ford Friendly chip?
- Coolant Filter
- Mobil 1 Synthetic ATF
- torqueshift issues
- puff of blue smoke on start up...bad, or normal??
- I need Aftermarket TBC install instructins for 05' f350
- Changing Fuel Filters on 6.0L
- silly question, How to remove fuel lines? anyone?
- What's a good on-line site for International or Motorcraft fuel and oil filters
- How does my EGR valve look to you? Pics inside.
- Oil cooler bad....
- 2006 F250 6.0 2377 miles $30k>>>Good Deal?
- New problem (battery light flickering)
- when does it end, more stripped bolts
- Injectors again, come on really!?!
- Coolant Filter Routing / Tap where / why?
- quick question on hfcm?
- turbo drain tube question
- up-pipe,manifold, turbo bolts
- How long do you let you truck cool down after a long heavy tow?
- 7.3 owner needs some help on the 6.0
- Rolllling start
- Non-servicable wheel hub bearing assy-Switch or just replace
- Antifreeze Nightmare
- does anyone have any interest in a 75,000 6.0?
- 130,000 miles, can i still add coolant filter?
- EGR Cooler replaced at dealer?
- comparing 2001 7.3L to 2005 6.0L
