quick question on hfcm?
Old Apr 9, 2010 | 01:04 PM
powerstroker100's Avatar
powerstroker100
Question quick question on hfcm?
Alright guys weekend is here its Injector replacement time, went to the dealer to get all my stuff picked up my two injectors and oil filter I ordered that new drain plug for the HFCM a while ago called the two dealers in the area one didnt know what I was talking about the other ordered it for me, International never called me back, so I ordered it and it still didnt come in today and I can get that bolt out but have nothing to put back in for the time being would it be possible to loosen the four bolts on the manifold and drain it that way? until they get this new upgraded plug for me? and would I need a new gasket?
Old Apr 9, 2010 | 01:10 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
If you can remove the OEM plug, why not just put it back in until you get the upgrade plug? Is the allen wrench opening stripped? I would think that you would need a new gasket if you remove the HFCM manifold housing cover...or chance a leak. You could just back the cap out and let the residual fuel flow into a catch container, install the new fuel filter and switch plugs later.
Old Apr 9, 2010 | 01:21 PM
powerstroker100
stock bolt has the daylights stripped out of it for the hex head threads are most likely eaten with rust, going to heat the bolt then tap with hammer and chisel and get it out because only other way is to buy the manifold kit and ford wants $120 that I cannot afford at the moment, I had a feeling the manifold would need the new gasket
Misky6.0
Oct 23, 2012 08:20 PM
powerstroker100
Apr 11, 2010 03:22 PM
brewer2007
Jun 24, 2008 06:04 PM
rblomquist
Sep 29, 2006 08:51 PM
gonnasellit_temp
Sep 27, 2004 07:31 AM
