4R100 problem
Old Nov 12, 2001 | 09:00 AM
lanero's Avatar
lanero
Post 4R100 problem
Old Dec 26, 2001 | 10:19 PM
3992824's Avatar
3992824
4R100 problem
This morning after I started my Excursion V10 with 4R100 and pulled it out of the garage, the 'off' light on the shift lever started blinking on and off. I know this is not a good thing! The last couple of weeks, I noticed that it didn't shift into OD as readily as it should have, and suspected that something wasn't right. I checked the fluid, and it's not burned, and is on the full mark. I've got 28k on it, and am probably due to have it changed, but I don't think it's overdue.
I had a 46RE go bad on a '97 Dodge Ram with 18k on it. I don't think I'm hard on my trannys. This is starting to give me a complex!
Old Jan 29, 2002 | 09:18 PM
rick_369's Avatar
rick_369
4R100 problem
Your trnasmission is in what's called "fail safe". the light on your shifter is like the check egine light for your transmission. YOu need to get it to a trans. shop, or dealer to have it scanned for codes
