Granny is killing me...
I don't know which tranny it has in it, but I can tell you this. It has the granny gear. I take off in second gear, shift into third at about 18-20mph, and if I really rev the rpm's I'll shift into 4th at about 35mph.
I'd like to get a little better performance out of the truck. Also it has absolutely no get up and go once you are in 4th gear. At 40-60 mph if you give it the gas like you are trying to pass or something it will slowly increase in speed. It's just not a peppy driver.
Is there any thing I can do about this??? I don't know if it is a transmission thing, the gearing in the rear end, or if it is a combination of a lot of things.
I've had the truck for a while, but have just recently decided to make it a lot nicer looker and driver. If I need to give info as to which transmission it has and which rear-end, I'll need some guidance as to how I find those things out. I'm sure there are numbers that tell me somewhere, but you'll have to guide me to where they are.
Thanks for the help.
Chad
As for the rear-end, look at the bolts around the pumpkin. There should be a metal tag on one of them. Get all the info off of the tag and post it here, someone will be able to de-code it for you.
As for getting more "pep" from your engine, check this company out:
[http://www.cliffordperformance.com]
They specialize in 6 cylinder performance upgrades.
Roger
Speedometer says 47,834. I've had it for over 10 years and I'm it has flipped the 100,000 mark once on me. If I were guessing I'd say
actual mileage is 247,000.
Below are the numbers from that tag. Can someone decipher this for me?
H82 - top left
7HB - top right
509 - bottom left
390B - bottom right
I've designated where the numbers were on the tag incase that makes a difference. Also they were pretty hard to read, so an "8" may really be a "B" and vica versa. Thanks for the help.
Chad
